new 48v 12ah lifepo4 charges to 57v,cuts off at 51v after 12 miles, is this normal?
3 posts / 0 new
beachebika
beachebika's picture
new to this,just got 48v 12ah lifepo4 w/48v 1000w motor,cuts off at 51.5v after 12 miles,how do I
get more range?
Last seen: 6 years 12 months ago
Re: new 48v 12ah lifepo4 charges to 57v,cuts off at 51v ...
It seems that your controller cut-off voltage is too high for a 48 volt battery. 51 volt shut-down is more in line with a 60 volt controller setting! Set your cutoff near 42 volts, and you will get more range, or get a 60 volt battery. (If the controller/motor are designed for that)-Bob
beachebika
Thanks Bob,I'll look into adjusting my controller or replacing it.I have a 48v 15ah 1000w kit from Golden Motor.ca on its way,I think their controller is programable,I paid $30 for the cord to plug it into my PC.
DIMITRI
