Evt 168 motor issue
I have changed the bearings in this hub however when i put the 2 parts back together they seem like a tight fit what if anything can be done to make this work properly when useing the bike it heats up and can only ride it half a mile because it is a tight fit thanks for any kind of help.anyone out there ever resolving this issue would be a great help thanks again.
Comments
If things do not rotate freely, something is WRONG,and forcing it to operate is likely to burn up the motor or controller, and may also damage your battery! Take it apart, find out what is wrong!--Are the correct bearings and spacers properly installed? Are windings and magnets in good condition, and is everything properly assembled? Getting someone else to assist may be worthwhile.-Bob
Hi thanks for the info im finding it difficult to get the help to put this hub back exactly as it should be its weird how the unit is tight all magnets and points are all in good order.
Thanks for the info i am trying i have taken the unit apart all seems to be in good order however the 2parts fitting together seem to cause the drag i want to sand down a surface to give it some clearance however this will cause the magnet to be less efective so what could it be shims how does this change things who are the guys with good knoledge of shims i would love to get this awsome bike working the company ecycle in vancouver do not want to try to fix it they want me to spend a 1000 bucks on a new hub instead. oh well someone out there has the solution me hopes thanks again.
