Hi there,
here is the the link to GP´s datasheet of our Vectrix-cells: GP30EVH
@ Mik: somehow I managed to add this to the col.handbook. Pleas check if I did the right way and place...
@ all recomendet discharge 60A continuous and !90A! pulse (5 secs!!). This is one reason i don´t want the 68mph upgrade puting
the cells above their limit. I try to contact my nearest dealer for a testride with the 50mph firmware. The other interesting fact: servicelife is about 1500 cycles (80%DOD at 1C).
Greetings Mike
These specs are a big worry.
Even with the 102km/h max software the maximum current draw far exceeds the specified max current draw. It's peak is way over 200A at full acceleration at 75km/h.
The max regen charge current is also higher than the specs.
Check the specs on the NEW vectrix cells? Gold Peak, #GP30EVLF. It seems likely that a 60 AH package could be fitted, doubling the single-cell specifications!--->50 miles, at 60 MPH anyone?---I want it!!!--Bob Curry
http://liionbms.com/pdf/goldpeak/GP30EVLF.pdf
that would do for me.
GP obviously changed the specs.:
Weird!
I downloadet the datasheet yesterday from GP. Well there are differences in max current-draw,
min. discharge temperature and other specs. both the single cell- and the 12v module-specs
seem to be identicel. maye the changed the specs to the lower values, because of problems
with cell lifespan, or they changed the internal structure of the cells?
Has anyone a god contact to GP?
GP contacts worldwide
Greetings Mike
I think we don't really know what cells are in the VX-1 !
All I have seen were data sheets for cells that look like the Vectrix VX-1 cells - but that's where the certainty ends!
Small changes to the chemical composition of the electrodes and/or separator and/or electrolyte can make massive differences to the specifications of the cells.
The names are different, too: There seems to be a different number at the end of the cell names:
GP30EVH vs GP30EVH04
The devil is in the detail!
Thanks Mikemitbike for GPINA.com site info.
Big list of Larger Batteries here: http://gpina.com/Electric_Vehicles.cfm
Electric Vehicle Batteries - Gold Peak Industries North America
(including: GP30EVH_DS.pdf doc info: ERS0130 Rev01 11/05/2010 12:51:59 PM)
singles and packs for types
LiFePO4
LiMn2O4
NiMH
Has anyone seen a pricelist for this table?
The AndyY1 link to image on Shrani.si http://www.shrani.si/f/27/MQ/wGsyHFc/nimh.jpg
is for 10/GP30EVH04
And Google found a pdf version on same site: 10GP30EVH04
This shows bottom of page with Date: 01/2004 and the Doc Prop's with
Modified: 14/01/2004 3:17:46 AM
GPINA.com is 10/GP30EVH also NB the 04 is missing.
This has green footer and header
Also footer info shows: ERS0130 Rev1
Modified: 4/08/2010 3:51:05 PM
Then this one linked to Here on VisV only has green Header but same:ERS0137 Rev1
http://www.evbtech.com/Data%20Sheet%5CTDS%2010GP30EVH.pdf
This shows bottom of page with Date:ERS0137 Rev1
The pdf DOC properties show: Microsoft Word - ERS0137 TDS of 10GP30EVH09 rev1.doc
Modified: 27/04/2010 11:18:30 AM
So this version looks like release 09 of the spec.
The ..04 and ..09 extension could be the year.
The Weight has changed from ..04: 8.2Kg to ..09: 8.6kg
And internal resistance: ..04 <14mOhm fully Charged to ..09 <12mOhm (But this info is probably for impedance at 1kHz not DC)
And Temperature info too.
Charge and Discharge curves an recommendations are different
..04 has 3A to 9A, and
..09 has 6A (0.2C) to 15A (0.5C)
and graphs are more generic in later version and miss the 3C rate.
It did seem strange that they had sprooked the 350A Max Discharge in the early version.
That's over 11C rate but as a 1sec pulse its feasible with the disclaimer "with Ventilation Cooling".
Things may start to fuse out over that.
But as the disclaimer says on the bottom, Not for Warranty purposes.
* The above information is generally descriptive only and is not
intended as guarantee or warranty. Cell and battery specifications are
subject to change without notice. All descriptions or warranties are
contained solely in specification sheets accompanying formal offers.
Please consult GP for conditions of application outside those
described in this document.
I though i'd post some info as these files may disappear.
10/GP30EVH04 01/2004
Type : Rechargeable Nickel Metal
Hydride Prismatic Cell
Model : 10/GP30EVH04
Nominal Dimension : 388 x 107 x 96 mm3
Nominal Voltage : 12 V
Nominal Capacity : 30Ah at 15A discharge to
10V/Module or 1V/Cell at 20oC
Specific Energy : 44 Wh/kg at C/3 discharge
Specific Power : 200 W/kg at 100% SOC/5 sec.
Charging Current : 3A to 9A recommended
(Consult GP for higher current fast
charge)
Charging Termination : -dV : 0mV/cell to 10mV/cell
(Consult GP for other TCO : 45 oC to 50 oC
charge controls) Timer : 100% nominal capacity
input
The above 3 charge termination
controls must be used concurrently
Max. Charging Temp. : Cell temperature must not
exceed 50oC
Service Life : >1500 Cycles
Weight : 8.2 kg
Internal Resistance : Below 14 mΩ upon fully charged
Ambient Temperature : Charging : 0oC to 50oC
Discharging : 0oC to 50oC
Storage : 0oC to 50oC
Max.Discharge Current : 350A with ventilation cooling
10/GPE30VH09 ERS0137 Rev1
Hydride Prismatic Batteries
Nominal Dimension : H = 96.0mm
L = 388.0mm
W= 107.0mm
Capacity : 30Ah at 15A (0.5C) discharge to 10V / module at 20℃
Specific Energy : 42Wh/kg at 0.5C discharge
Specific Power : 121W/kg with 80% SOC at 3C 30 sec.
Energy density 90Wh/L at 0.5C discharge
Power density 261W/L with 80% SOC at 3C 30sec.
Charging Current : 6A (0.2C) to 15A (0.5C) recommended
Charging Termination : -ΔV : 0mV/cell to 10mV/cell
(Consult GP for other TCO : 45℃
charging conditions) Timer : 100% nominal capacity input
The above 3 charge termination controls must be used concurrently
Max. Charging Temp. : Cell temperature must not exceed 45℃
Max. Charging Current 30A (1C) continuous
(Consult GP for high current fast charge)
Max. Discharge Current : 60A (2C) continuous
90A (3C) pulse for 5s
Service Life : >1500 cycles (80%DOD at 1C)
Weight : ~8.6kg
Internal Resistance : <12mΩ
Ambient Temperature : Charge : 0 to 45℃ (conditionally)
Range Discharge : -20oC to 50℃ (conditionally)
Storage : -20 to 35℃
