For those who understand the importance of equalisation charges, but do not want to or cannot build their own simple charger, there may soon be an alternative:
http://www.insightcentral.net/forums/174648-post634.html
Hi Mik,
Good find. Great idea. But does the harness (like PTC resistance) depend on existing cell level or sub-pack level wiring? Cell level monitoring? How are 102 cells or 12 sub-packs monitored with a 9 pin connector?
When I proposed using RC chargers for that purpose one of your objections was the necessity of wiring balance connectors for each 8 or 9 cell block. Why (respectfully) is this an improvement in that respect?
Best Wishes!
Mitch
It would need to be adapted somewhat to connect to a Vectrix, but it will only need connection to (possibly diode protected) tabs to cell 1 and 102. And connection to the impeller 12V input via some sort of ABCool relay.
The charger is not being designed designed specifically for the Vectrix, but if someone with a Vectrix would buy one then Mike would maybe make a custom version - there might be a significant market for it.
My main concern is that the built-in 12V supply of the charger may not be able to cope with the VX-1's current demand of 4A @ 12V DC for the impellers. Some very powerful cooling in that bike, compared to other NiMH batteries!
But the average "Freddy" does not have that 12V source built in, either.
Hi Mik,
A Vetrix specific version would be best and probably worth the effort for Mike.
I don't think a 4A 12V DC supply will be a show stopper. Any mention of a price?
Does the following mean that the newest Vectrix Charger Firmware performs equalization (sounds like it should run the fans):
http://endless-sphere.com/forums/viewtopic.php?f=12&t=17071&start=15#p321387
Best Wishes!
Mitch
