How would you diagnose, test and restore a Vectrix battery?
49 posts / 0 new
Last seen: 5 months 3 weeks ago
Re: How would you diagnose, test and restore a Vectrix battery?
Superb Work. Thanks for sharing.
If I understand it correctly, you had a cell reversal at 122V. If the vectrix's undervoltage limit is 115v, it can explain why there's some huge problems with the v's battery: Cells reversed at every end of discharge, not nice for the v's life expectancy.
Suggestion to V users: Avoid discharging under 130v?
the voltage at which cell reversal (and which cell) happens is different every time (even for the same pack).
it depends upon pack balance, and temperature mostly.
It was interesting that the first to reverse was not one of the ones that were reversed during before shipping.
also interesting it was a top layer cell.
usually those have the best time due to first access to cool air from the fans.
though the top layer cells, usually being at higher SOC, are more likely to be overcharged...
bulging is probably more from overcharge than overdischarge (internal pressure is highest under normal operationg at SOC 100%)
sitting on the floor, the top layer would be the warmest, so would self discharge the most.
all theories :)
29Ah before first reversal is pretty good.
in practice, below half bars (~15Ah) the charge isn't reliably there in summer.
below 2 below half bars (~20Ah) the charge isn't always there in winter.
cell 33 looks healthy :)
reversal at 0.1A looks to be reasonably safe.
Indeed! I don't know why.
I think this is incorrect. The air gets sucked from the bottom to the top of the battery, then through the impellers. They do not blow in, they suck air out of the battery! The top layer also heats up most in the sun. See https://www.endless-sphere.com/forums/viewtopic.php?f=14&t=6277&start=45#p157390
I thought that all that damage to the Vectux battery was due to over-charging of the lower levels. Almost all damaged cells were in the bottom layer in the Vectux. See https://www.endless-sphere.com/forums/download/file.php?id=15767
I agree. But maybe this cell is just one with a defect? Further testing, particularly self-discharge testing, might give us more clues!
all theories :)
True - but I started the discharge within minutes of disconnecting the 0.3A charge current. The self-discharge should have been very minor - and does not explain the bulging of just that one cell!
Maybe I'll individually discharge a few cells after the self discharge test is done in a few weeks, to see how much is left in other cells when cell 30 is empty. I missed the chance to measure it this time - the battery is already almost fully charged again.
Indeed!
As do the other 2 reversed cells in the front pack - at least they are invisible now.
Is that how you discharged it?
I assume it all depends on the length of reversal and the current - and the product of the two, the amount of reverse Ah.
With a well balanced battery the reversed Ah will be few - but if you discharged a damaged battery, like the Vectux battery, at 0.1A, then the 12Ah or of reversing at 0.1A would probably kill the weak cells for good!
That is in principle correct - but is different for every battery, as Antiscab already mentioned.
The capacity and SOC of the weakest cell determines when it begins to reverse. Exceeding the capabilities of the weaker cells in the pack regularly will kill the weak cells quickly - within a few thousand km or less.
This destructive effect on the weak cells is often accelerated by attempts to "calibrate" the gauge with a deep discharge. That is the worst thing you can do to an already weak cell in the battery! As a minimum requirement, an EQ charge should be done before any deliberate rides until the red battery tell-tale lights up.
But if the weak cell has already significantly lowered capacity, then it will get reverse charged during the ride - and then overcharged during the following charge. Both are very bad for it.
The reversed cell 30 in this pack is located exactly in the hottest position in the Vectrix pack: Right side, top layer of front battery. That's the "up" side when parked on the side stand and located closest to the ~80degC hot black plastic cover facing the sun.
My hypothesis for how the cell got damaged is this:
1) Self-discharge due to solar heating.
2) followed by reversal during riding, causing some damage and eventually capacity loss.
3) followed by over-charging, causing the swelling.
I am now in the process of doing the self-discharge test on the "New Used Battery" (NUB).
After a full charge it was left standing for 15 days in about 20degC temperature before the test.
The first part was discharge through a resistive load with monitoring of current and voltage by the PoScope Monitor (with a x100 probe for the voltage and a 10mohm shunt to measure current).
During this, I did repeated manual voltage measurements of the accessible cells and modules, including the three IDeA segments. It all works well as expected.
The first (only) cell reversal occurred after about 19.6Ah had been drained at 6.2A.
IDeA voltages:
Before start of discharge:
1: 45.02
2: 45.02
3: 45.08
Just before the reversal was visible on the PoScope graph:
1: 42.12
2: 42.12
3: 42.20
During the cell reversal:
1: 40.47
2: 41.82
3: 41.94
A couple of minutes after removal of the 6A load:
1: 42.47
2: 42.50
3: 42.54
The reversing cell was number 33 - the one in the front top layer that had been at zero volts when the battery arrived.
Cell voltages module 4 during the reversal:
Cell 28: 1.233
Cell 29: 1.232
Cell 30: 1.227 (has lowest capacity (without self-discharge, immediately after charging) and swelling)
Cell 31: 1.233
Cell 32: 1.227
Cell 33: -0.2199 (highest self-discharge rate in pack)
Cell 34: 1.226
Cell 35: 1.229
And this was even visible before the start of the discharge:
Cell 28: 1.322
Cell 29: 1.320
Cell 30: 1.318
Cell 31: 1.323
Cell 32: 1.318
Cell 33: 1.287 ....(31mV lower than the next better cell!)
Cell 34: 1.320
Cell 35: 1.321
I think I might have an explanation for the three cells that had zero volts upon arrival: The pre-transport discharge was probably not done immediately after a complete EQ charge. Those three cells have a higher than average self-discharge rate (SDCR), higher than the SDCR of even the swollen cell 30! They discharged themselves during the period between the last charge and the deep pre-transport discharge, so that they ended up reversing during that discharge.
It remains to be seen how much is left in the other cells, including the swollen cell 30 and the two cells hidden in modules 5,6,7 or 8 which were also at zero volts upon arrival of the battery.
The IDeA segment voltages before and during the discharge seem to support my suspicion that there are two more high-SDCR cells in the middle and lower modules of the front battery, but luckily not as bad as cell 33.
I have dusted off my CBAIII and am now running further 6A discharges on those cells that I can access.
First result of this: Cells 28-32 discharged a further 3.4Ah until cell 30 (the swollen one) reversed.
That makes 19.6Ah + 3.4Ah = 23Ah for cell 30 after 15 days of self discharge.
Interesting,
for interest the pack had an EQ charge performed before removal from the bike, but waited around 3 weeks while I discharged it really slowly on and off.
It was cold at the time, the pack temperature was less than 20 deg C the whole time.
being one of the reversed cells suggests the high self discharge rate has been there for some time.
I wonder what caused it.......
does suggest that any deep discharge has to be within a few hours of a full EQ charge.
so all cells lost 5-6Ah in a fortnight to self discharge.
I wonder if most of that was in the first day.... (that would be a pain to plot)
Exactly why I keep going on like a broken record that the EQ charge should be done before any (planned) ride to the red light for gauge calibration! Otherwise it is poison for the cells with increased self-discharge rate.
Unfortunately I did not measure the remaining capacity in the cells after the first discharge. I just stopped when cell 30 was empty after 29Ah and recharged. I wish I had put in the effort, because it would be helpful to know!
So now I cannot tell how much they lost, except for cell 30, because I do not know how much they had after a full charge without time for self-discharge. But I can repeat this test quite easily with part of the battery. Maybe charge module 4 up again, then discharge until cell 30 reverses, then repeat what I am doing now - but all without any time for self-discharge.
I guess about half of it disappeared on day 1. Maybe I'll try it out, but the temperatures are now rising rapidly here and that will throw everything out. If I find a module with all good cells with similar SDCR, then I could charge them up, then discharge one of them each day and see what is left!
Anyway, all I can say with certainty is that cell 30 lost 6Ah in 15 days, and cell 33 lost more than 9.4Ah in 15 days - but I don't know how much more. It could be a lot more, because I keep finding cells with much leftover capacity as I work my way through:
Cell 33: 19.6Ah
Cell 31: 19.6+3.4+??? (not finished yet)
Cell 32: 19.6+3.4+??? (not finished yet)
Cell 30: 19.6+3.4=23Ah
Cell 29: 19.6+3.4+5.7=28.7Ah
Cell 28: 19.6+3.4+5.7+1.89=30.6Ah
That all looks like it might be worth it to take the pack apart to replace a few cells. 30% difference between worst and (so far found) best cell is a bit much, even for a sacrificial cell.
Here are the capacity results for module 4 (15 day SDC):
Cell 28: 19.6+3.4+5.7+1.89= 30.6Ah
Cell 29: 19.6+3.4+5.7= 28.7Ah
Cell 30: 19.6+3.4= 23AH
Cell 31: 19.6+3.4+0.9+4.5= 28.4Ah
Cell 32: 19.6+3.4+0.9= 23.9Ah
Cell 33: 19.6Ah
Cell 34: 19.6+7.8= 27.4Ah
Cell 35: 19.6+7.8= 27.4Ah
Cell 33: 19.6Ah
cell 28 must be in unusually good condition.....
30.6Ah after 15 days would suggest either *no* self discharge, or better yet well above average capacity.
It may be worth seeing what its actual capacity is straight off charge.
Yes, definitively the best one so far! But not out by very much...
Here are the results for module 9:
Module 9 totals:
Cell 75: 19.6 + 6.4Ah + 1.1 = 27.1Ah
Cell 76: 19.6 + 6.4Ah = 26.0Ah.
Cell 77: 19.6 + 6.4Ah + 1.1Ah + 0.7Ah = 27.8Ah.
Cell 78: 19.6 + 6.4Ah + 1.1Ah = 27.1Ah.
Cell 79: 19.6 + 6.4Ah + 1.1Ah + 1.5 = 28.6Ah.
Cell 80: 19.6 + 6.4Ah + 1.1Ah + 1.5Ah + 0.4Ah = 29.0Ah.
Cell 81: 19.6 + 6.4Ah + 1.1Ah + 1.5Ah + 0.4Ah = 29.0Ah.
Cell 82: 19.6 + 6.4Ah + 1.1Ah + 1.5Ah + 0.4Ah = 29.0Ah.
Here are the test results for the 15 day self-discharge test of the used Vectrix battery:
Photobucket
The testing took 5+1/2 days (but three were workdays) - it takes several hours before and after work and all day on the weekend to get this clear picture of the battery. If you do it slower, than the contining self-discharge will make the results biased (towards showing higher capacity for the cells tested first).
The little red "S" marks the swollen cells in the pack.
Incredible... two cells around 20Ah.
Iguess that the useful capacity of this pack is only around 19Ah.
Incredible... to cells around 20Ah.
Yes, but only after 15 days without an EQ charge!
Straight off the charger the capacity was about 29Ah for the weakest cell. The latest test with my CBA III (still running) seems to imply that my rigged-up whole-pack discharge method was out by (only!) +3.5% - meaning the real capacity was about 28Ah straight off the charger.
It just shows how important it is to do the EQ charge before the deep discharge - and how differential self-discharge rates can wreak havoc to a pack that would seem fine in a simple charge-discharge test.
For NiMH pack longevity (and I mean the difference between 50000km and 150000km) the frequency of EQ charges needs to be kept very low. That is very important, but not as important as preventing any cells from reversing.
Those cells in a NiMH-pack which have an increased self-discharge-rate (SDCR) will sooner or later reverse if the EQ charges are kept to a minimum.
The bigger the difference in SDCR, the sooner EQ charges will be needed.
The bigger the temperature difference between cells, the larger the differential-SDCR, the sooner an EQ charge is needed.
The more EQ charges are needed, the sooner (= 50000km instead of 150000km) the pack deteriorates.
If EQ charges are delayed, then cells end up reversing. That kills the weak cells, but leaves the rest of the pack in good shape.
This should make it clearer: I have recharged Module 4 selectively and tested all cells in module 4 immediately after a full charge.
Cell 28 had more than 36Ah capacity tested that way (@6A).
Photobucket
And here is a graphical representation of the 15-day self-discharge capacity of all cells in the pack:
Photobucket
Its sorta starting to look like Vectrix corp compensated for the poor balancing problem by derating the probable capacity of the cells. (or maybe GP did that).
I wonder what the actual capcity is at 45A continuous? (70-80kmh continuous)
IIRC, the CBAIII can do up to 45A continuous at 1V.
clever graphics.
Recent charge gives more range.
Self-discharge in NIMH is very high (30% every month).
Some cells show higher self discharge rate than the rest(near 60% per month)
Thanks to Mik's tests now it is quite easy now to understand why some cells get damage after 10.000-20.000 km...
I think 25A is the CBAIII max for a single NiMH cell, I tried it when I analysed the Vectux battery. It has some problem regulating the current at low voltage levels, therefore cannot do a lot of current at 1V, although it is far from it's theoretical 100W rating. And above 20A it always gives a warning before the test starts, so I chose 20A as the test current with the Vectux battery.
With this battery, I could only use 6A for the whole-pack discharge part to the first cell reversal. Therefore I continued at that current so that the results can be compared. The maximum current that the CBA III can handle for a 9-cell module is 8A IIRC. In order to get comparable cell level capacity results, the discharge rates need to be the same.
Maybe I'll try out the 45A continuous capacity on one of the rebuild 9-cell modules from AZVectrix' donated cells. The AMPEASEL can easily do that current level. And sooner or later those cells will need to be cycled during their wait. The Vectux pack with M-BMS continues to work so well that I don't want to take it apart.
mikemitbike
mikemitbike's picture
To bring this Post back to life. One of the problems of testing the single cells is the time that is needed for.
I bought the "big brother" of the Vectrix Cells the 10GP80EVS modules (used ones, 10 cells each 78Ah) for my
electric Pandawhich is equipped with lead-acid-gel batteries now. As I had not the patience to test each cell,
I decided to test each block to a cutoff-voltage of 11,5 Volts. Here the results after testing 50% (not all on
the picture):
Near cutoff I check the voltage of each cell in the block. If the cutoff is reached before measuring, I start a second test
with the uncharged battery and check the voltage then. So weak cells can be determined rather quickly.
Some other thing is quite interesting, the voltage is droping VERY fast if the battery is nearly depleted. Even the very
healthy block F did loose voltage very quickly below a theoretical cell voltage of 1,2 Volts. The Blocks where all discharged
with a rating of 7 A. As the Vectrix cells have a "compatible" chemistry and might be discharged with 7A when you are limping
with 30Km/h the discharge curve might be similar. To the point: when riding slow to discharge the nearly empty battery it might
be dangerous to discharge below ?120V? because at that point a weak cell maybe starts to reverse.
Greetings Mike
