Lithium ion batteries in place of lead acid
3 posts / 0 new
jimmidan
Last seen: 2 years 3 days ago
I I swapped out the 36 volt sealed lead acid batteries in my EV Global e bike with 36volt lithium ion batteries, can I keep using the built in charger used to charge the lead acid batteries?
Reid250
Re: Lithium ion batteries in place of lead acid
YES/NO
You can use it but you will end up undercharged. Best to get the proper charger to take advantage of the max storage.
7circle
7circle's picture
YES/NO
The only reason it would be under charged is if the charger at no load voltage is less than the 3.8V/cell needed to get to full charge.
If the a 36V lead acid should float charge to 2.3V/Pb-cell x 18 = 41.4V
So a liIronPOOOO pack charged would be 3.8 x 12 = 45.6V
So if you use 11 cells of LiIronPOOOO then the charged pack voltage is 3.8 x 11 = 41.8V
Thats 0.4 less for the whole pack, it depends on the BMS setting for full voltage.
Now if you have a BMS on your pack that cuts off charging when they are full at 3.795V your fine. These decimal places just show that is a bees little toe of a difference.
So it comes down to what your Lead Acid Charger does.
But if you don't have a multimeter and feel like you know what to check... best to get someone to measure your charger characteristics.
Or by a charger for $100. (I hope less)
Have you got a picture of your charger? The model and ratings?
