Boreem Jia 602D
4 posts / 0 new
tempustemper
Boreem Jia 602D
I just got one of these for $40 and i am rather pleased with it. Makes going to the post office more fun and keeps me from turning on the CUV every day.
My question here is.
How oftern should i charge the batteries, where would i find a repair manual, and if ther eis no repair manual how do make the brakes work better?
mr_exon
Re: Boreem Jia 602D
Easy Load - Easy Folding - Easy to Carry
Motor: 250 Watts
AC Voltage: 110V/220V
Battery: 2pcs. 12V 12AH Lead Acid Battery
Front Shock Suspension
Chain Belt Drive
Rear Trunk With Reflector
12 inch aluminum wheels and Air Tire
Charge Time: 3 - 5 Hours
Runing Time: 1.5 - 2 Hours
Load Capacity: 200lbs
Weight: 75lbs
you dont need the manuel, that is a simple scoot
charge it every other time you ride it.
if you ride it a lot, then buy two more 12v12ah cells for it on the side so you can always have a charged pack ready and the other can be put on charge for later...
but for real charge time, go with about 1hour of run time to be safe
I just Re-laced my first spoked wheel! and it was trued by spinning it in my hand
Deafscooter
Deafscooter's picture
Re: Boreem Jia 602D
Deafscooter is Here...
ask deafscooter about boreem scooter modding
check on http://www.austinev.org/evalbum/480
Craig Uyeda
Deafscooter
deafscooter
littlebitdecker
littlebitdecker's picture
Last seen: 18 years 2 weeks ago
Re: Boreem Jia 602D
We have 2 of them we purchased several years ago.
Electric Rider carries Boreem parts.
It should have Band Brakes, which are fairly easy to adjust, never use a lubricant on them.
