Well the Blade is apart once again. It seems that every time I get it together and running I know I can still do more to get better performance. So apart it goes again. This time is to upgrade to 72 volts , new brake assemblies, plug braking ,tires and much more. Want to compete in the 200cc and under class at our local Supermoto track. I will keep you posted.
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
- xovacharging
Here is a pic of the new front 6 piston caliper and 225mm full float rotor.
Rear 205mm sawtooth rotor with 6 piston caliper.
Micro switch installed on rear brake lever for braking contactor control.
Hope to have the brake contactor and coil resister installed tonight. Will add pictures shortly
That's a very nice looking bike, about how much have you put into it?
I can't say for sure what I have in the bike so far. I has to be in and around $5500 ++++++++++++. Every time I have it together and running, it's apart the next week to make it a little quicker with a higher top speed. I am now in the 55-60mph range. Having problems stopping now. Too much of one causes more problems in another. Hope this will be the last mods in a while.
