4WD Electric Skateboard Questions
25 posts / 0 new
joshpit2003
joshpit2003's picture
Last seen: 13 years 4 weeks ago
Hello everyone.
I've been researching a whole lot of different ways for me to go about making a gnarly 4wd skateboard.
Target specs:
4WD: 4 x 350-400 watt motors (one on each wheel)
24V system: 2 x 12V SLA 24Ah Batteries (seems to be the best "bang for the buck when it comes to batteries)
35MPH top speed
6-8 mile range
The issue I am running into now is that I can not find the correct motor-controller(s).
I'm looking for a motor controller that offers Variable Regenerative Braking.
The closest thing I have found that is what I am looking for is this:
http://www.evassemble.com/index.php?main_page=product_info&cPath=11_5&products_id=62
The only problem w/ the above is that I would need Brushless motors if I wanted to use the 350 watt brushed motors that I can get a killer deal on.
My questions:
1. Is there a 24V motor controller rated for (50A or 100A continuous) that offers variable regenerative braking for Brushed motors. (Basically I think what I am looking for is the above linked controller but for Brushed motors)
2. Is there an inexpensive 350-400 watt brushless motor that can be direction reversed (2 of the 4 motors would need to spin in the opposite direction) and can also be externally controllable via the above linked controller?
Thanks a bunch for any help. This school project is turning into a nightmare of back and forth research, so any help is appreciated.
joshpit2003
Re: 4WD Electric Skateboard Questions
Well I found these motor controllers:
http://kellycontroller.com/24v-kd-brushed-dc-motor-speed-controller-c-22_39.html
I can't quite tell from their specs if they allow a seporate input for regenerative braking or if they are just always braking when not accelerating.
I also wonder why on earth they are 4.5 LBS?
These ones are tiny, and are almost what I am looking for, but they don't offer a "Coasting" mode:
http://www.dimensionengineering.com/sabertooth2x25.htm
colin9876
I wouldnt get too hung up about regenerative breaking - you really dont get that much back (maybe 2 or 3% and thats on a bike), and it Really wouldnt be worth it on a skateboard.
Brushless motors are great, model plane out-runners can produce in the range of 500w, two of those (not 4) would be enough, and also they run off around 11volts so a 3 cell Lipo can be used which saves loads of weight.
joshpit2003
Thanks for the tips. The Regen isn't so much for efficiency, but more for the need to have brakes. mechanical brakes would not allow a dead-mans switch and would also add complexity to the design. I think Motor braking would be ideal in such a situation.
As far as brushed vs brushless I haven't been able to find a good "bang for the buck" brushless motor. I have found 20 dollar 350W brushed motors, and haven't been able to find any brushless equivalants in the 50 dollar each range. I'd also like to get a motor made for a similar application. Example: e-bikes, scooters, go-carts, heavy robots all are similar, while remote control car/plane motors don't seem like the wise choice for reliability. Again, I'd love to go brushless (especially since I already found a controller for brushless), but I'm not seeing "bang for the buck". (would love someone to prove me wrong)
I'm talking to someone now about SLA alternatives, but from what specs I have been reading it will cost a fortune to build a non SLA pack that can handle the amp draw of 4 motors. (80 continuous, 200 peak for the current motors I have in mind)
4WD is a design goal, already built a 2WD one, and 2WD was a hell of a lot better than the typical 1WD. So 4WD is likely to be a hell of a lot better than 2WD. Not the best logic, but this thing needs to be 4WD for design sake.
joshpit2003
I didn't get many questions answered here, but thanks Colin for responding.
Here are some pictures of my 4WD Electric Skateboard:
//i24.photobucket.com/albums/c43/joshpit2003/Tulberg_Hero_2.jpg)
//i24.photobucket.com/albums/c43/joshpit2003/Tulberg_Motor_Wheel.jpg)
//i24.photobucket.com/albums/c43/joshpit2003/Tulberg_Bottom.jpg)
Specs:
24V DC SLA Battery System (22Ah)
350W DC Brushed Motors (One on each wheel)
300A Motor Controller w/ Regenerative Braking ability
Dead-Mans break set at 20% if you fall off.
E-Glide GI Deck
Bionic Trucks
MBS Wheels/Tires
24MPH Top Speed
1400W Total Power
85lbs *yes that's heavy
very tight turning radius, I would guess 5 feet.
total cost: Close to 1200 bucks.
total build time: 1 full week.
more than willing to answer questions, just contact me via email:
(this user name) @hotmail.com
Thanks.
-JOSH
p.s. Regen braking works GREAT. It's the only way to go for a skateboard.
colin9876
Wow, looks fantasticly made.
And where did you take the photos, it looks like studio quality photography?
So how does it perform, can you make a Youtube video of you demonstrating it!!?
And the big question is Will you now be selling these? Lol!
joshpit2003
Thanks. I'm an Industrial Designer, and taking awesome photos is a pretty important part of design.
These photos were taken on top of a large white foam-core board, outside, on a slightly overcast day. (overcast days are great days for taking photos). Smaller objects typically get shot inside a photo-box w/ 4 or 5 lights on 'em.
I do not have any plans to manufacture this skateboard. I don't think there are enough people out there willing to fork out this kind of money! haha. But if someone has the $ and wants to contact me about it I've got no problem with that. But this one was built for the passion of building.
It rides great. Hits 24MPH very quickly. The 4WD is amazing... it PULLS you through the turns if your back wheels ever start to lose traction. The turning radius w/ these trucks is also amazing, I'd guess it's close to a 5 foot turning radius, which gives you the ability to make 90 degree sidewalk turns or complete 180 degree turns on a typical street. (Note: I don't actually ride this on the sidewalks, that's illegal and plain stupid for something this large and heavy)
I'll be sure to post a short youtube video once I get around to editing the footage (thats what takes forever).
Thanks for the interest.
-Josh
joshpit2003
4WD Electric Skateboard Video
http://youtu.be/jlab8wI8hwY
Above is the link to a youtube video of the 4WD Electric Skateboard in action.
Hope you like it.
-Josh!
colin9876
Re: 4WD Electric Skateboard Video
Awesome video, that kind of action with dust and gravel flying you drift round those coners is something Ive never seen from a skateboard before!
If Visforvoltage had awards I think you ought to get 'innovation of the year' award!
joshpit2003
Thanks. I didn't really design it for off-road, but the 4WD sure is great for "surfing dirt".
colin9876
One thing Ive been wondering about ...
Because 2 of the motors must be effectively 'running in Reverse'
Did you have any issues with this?
Many motors have their brushes adjusted with a timing offeset (the brush positions are advanced slightly to take account of inductive delays)- this makes them more efficient in one direction. The downside of this is that they are less efficient in Reverse. Im not sure if your motors were set at midpoint so they were equally fast in both directions?
joshpit2003
good question. To be honest I'm not sure. I know that the place I purchased them from said the polarity could be switched for reversing the motor direction, but that doesn't necessarily mean the motors were designed to do that. Ultimately it ended up not really mattering, because if there are any effects I don't notice them at all. It accelerates and decelerates evenly. And when you lift all 4 wheels off the ground and then accelerate they all start to spin at the same time. (but that's not telling me how "efficient" they are). Sorry I couldn't answer that question entirely.
colin9876
Yes, maybe these cheaper motors dont come with any 'Offset' and they are equally bi directional.
More expensive motors do come with an offset, you gain about 10% in the forward direction, but lose 10% (in power and top speed) in the reverse.
Maybe someone else can comment on whether the Chinese motors come non-directional as standard?
It would be good for someone else to comment on this thread, Im a little suprised at how few comments this topic has attracted given how exciting this invention is, and with the good video and clear pics etc. ....
Perhaps they're all to busy with their broken Vectix's to watch u burning rubber! Haha!
joshpit2003
I'd like to know as well. But either way it seems to work in this situation.
joshpit2003
another interesting thing is how I am running 4 motors off of just one controller. Some people would advise against that since you have a chance of frying your motors. But here is the benefit to running 4 (Brushed DC) motors (In parallel) off of just one controller: You get the ultimate traction. It's like having a positraction system on your vehicle and here is why: When 1 of the 4 tires loses traction, it's (motor) Amperage demand drops and the controller stops feeding it lots of amps and instead feeds the other 3 motors however many amps they are demanding. The end result is "amps only when you need 'em". Now here is where it could be bad: If for some reason you lose traction on 3 of the 4 tires, and the 1 tire is stuck in a rut or something, then that 1 motor could "eat itself to death" by demanding too many amps, and the controller would have no problem supplying the extra amps since the other 3 motors aren't using them.
If you were to run 4 motors in series w/ the motor controller (and battery-pack) you would get the opposite effect. When 1 of the 4 tires would leave the ground it would become the only tire spinning and the other 3 tires would lose all power. (like an open differential).
So thats why I chose to just run a 24V system and 4 Brushed DC motors in parallel w/ a single Brushed DC motor controller.
I remember people telling me that this isn't an option for Brushless motors because they would eventually become out of sync with each other and the controller would have no way of syncing multiple motors. I do wonder though:
Can you run multiple sensorless brushless motors in parallel with a single brushless motor controller?
colin9876
No cant do it with Brushless motors because the controller uses feedback from the motor (either Hall sensors or back EMF) to phase the supply.
Interesting point parallel vs series.
The controller delivers the volts (lets say full speed 24v) and then the current will be divided in inverse ratios to the resistance of the motors. Faster turning gives more back EMF and equivalence of resistance - so as you point out the slower motors take a bigger share.
Good system!
joshpit2003
Thanks for that info. I didn't know sensorless BL motors used back EMF. Learning something new every day.
Looks like I'll be needing 4 speed controllers if I want to run 4 brushless motors in the future. I've noticed people claiming that the sensored BL motors perform better especially on start-up under a load (like starting from a stop on a skateboard), so I'll likely be looking for a sensored BL Motor Controller.
KYLESum98
Hey
Josh i think the skateboard is really cool but i was wondering what motors, batteries and the controller did you use and where you brought as i would like to build something similiar.
joshpit2003
Thanks Kyle.
I used scooter motors (you can purchase 'em from any scooter supply store) , SLA batteries (12V 22AH) (you can purchase those anywhere, but i like "battery-spec" *worst looking website ever made, but lots of good info on it*) , Kelly Controller (this is the tricky part because Kelly's require two seporate inputs to work. Throttle and brake each need their own potentiometer. There are other "scooter" controllers that work but they dont typically give you variable braking. Good luck finding the correct combinations of parts. I'm sure there are a lot that will work together. ANy more questions shoot me an e-mail. joshpit2003 @ hot----.com.
Patrick Brathwaite
Hi Josh,
Wanting to try something much less ambitious. Was wondering if a brushless motor and controller for a larger RC truck might work? Thought to use a belt drive transmission line as seen in many commercially available skateboards.
The systems I have been looking at seem to have impressive specifications. Controllers capable of handling large currents in tiny form factor. Motors designed to to work in hostile environments. Is there some obvious flaw in my thinking here?
Controller motor combo.
Would really appreciate some input.
joshpit2003
Hi Josh,
Hey Patrick.
I have seen quite a few people use the RC parts.
I would not advise it, as those motors and motor controllers are designed to push around 10 lbs, while you will be pushing around 150+ lbs.
The main issue I have noted through other ppl using the RC stuff is the motors losing "sync", so many times you need to "baby" it up to about 5 mph, then you can start to use the full-power of the motor. But again, I have never built a skateboard using RC parts, so I may not be the guy to ask.
As for the belt-drive... I hate it. Belt drive is notorious for "skipping", and thats because in order to put any decent power through a belt, it needs to be either SUPER-TAUGHT or SUPER-WIDE. And as you can imagine, a super-wide belt is a challenge to fit under a skateboard. Do yourself a favor and use ANSI 25 chain. It is very small, very fluid, and still able to apply a LOT of power w/o slipping or snapping. And as a side-note: chain-drive can be just about as quite as belt-drive if you do a good job aligning the sprockets and keeping the chain lubed.
Hope that helps.
p.s. I started an electric-skateboard company selling gnarly electric skateboards:
http://gnarboards.com/
Here is the most recent video:
joshpit2003
looks like I was not successful at embedding the video.
Here is the link:
http://youtu.be/8BY00if5F2o
Butchie Buie-long
where did you buy the batteries?
and where did you get the saw hub cap + wheels
woodsmith
Spacechariot provide you top quality & cheap self balancing real Hoverboards scooter . They are the top manufacturers of scooter by using the line materials delivering superior quality products.
Baum59
I agreed with you as I found smiliar on HyperOutdoor where I was focusing on learning more things like skills, tips, tricks to enjoy worthful experience by HyperOutdoor also I would like to meet up new peoples to follow the update on HyperOutdoor, is there anybody live near by spain?
