Thermopile?
11 posts / 0 new
atomicbeanie
Thermopile?
I was wondering if anyone had any experience with thermopile generators?
If the term is foreign (it was to me), it is an array of thermocouples used to generate current from heat.
Wikipedia Thermopile Article
Persona Non-Grata
Re: Thermopile?
Thermopile type generators sound like the closest feasible thing to free energy available to us, potentially only limited to the local ambient temperature as it approaches absolute zero. The main problem is that the energy per cost of the thermocouple effect is so miniscule that it has so far only been used as a measuring device, being amplified with a secondary supply of energy to even be read, almost every digital thermometer and thermostat has one in it. Theoretically using a thermocouple as a bulk power supply could be done, but it would require both a prohibitively expensive amount of thermocouple material and massive well calculated heat-sinks to provide a constant supply of heat from the ambient temperature. Some one could do it just to prove a point but it would not pay for even the land taxes required for an installation this size, even if it provided enough hydro to power its own lighting. Sorry to burst any bubbles, but there are more tangible energy priorities, such as tidal, that can be achieved with technology and technique available now.
With a hammer, a chisle can be made. With a hammer and chistle, files can be made. With hammer, chisle, and file anything else can be made.
Kaishan k500w retired, Merida TEV500 on indefinite sabbatical, currently using a Currie E-zip Trailz.
atomicbeanie
Re: Thermopile?
I think your analysis is correct. But I wasn't clear about what I was thinking.
I am wondering about small vehicles. The idea would be to use a boiler or just a firebox to put heat into a space with a thermopile surrounding it. On the outside of the thermopile would be fins and ducting so the air flowing past the vehicle could cool the other side of the junctions. I am thinking of such a power-plant to augment a battery for a super-light commuter type vehicle.
As for my bubbles, I am used to them bursting!
Thanks for the reply!
Atomic Beanie, makers of the new Watts Wheel for iPhone
gasdive
Re: Thermopile?
I haven't had any experience with them, but NASA has! The maximum power output is low, but it's constant, so it would recharge a battery pack quite well.
http://en.wikipedia.org/wiki/Radioisotope_thermoelectric_generator
Goodness, it would be the coolest thing! Sadly it works best in deep space where the ambient temperature is only a few Kelvin. I think it would work on earth if not quite as well.
Jason
Blogging my Zero DS from day one http://zerods.blogspot.com/
strawhistle
Re: Thermopile?
when i was a child 60years ago we had a ring of thermocouple ends that slipped over an Aladdin lamp chimney and would power a crystal radio at night! A lot of heat and very little electric energy! But the idea has been out there for a long time ( the wire was little pieces of copper and nickel welded together in series to form a chain and then every other end was formed into a ring and the alternate end was fanned out to dissipate the heat)!!! LaTeR
Re: Thermopile?
it would work ok, its the temp difference needed (the plutonium would just have to be hotter)
the real trick would be getting hold of the plutonium needed.
you could use a less radioactive material, but then you would also have less power.
Persona Non-Grata
Re: Thermopile?
I don’t know exact numbers associated with this effect, just general tendencies. It might work as an auxiliary power supply, if the correct numbers can be achieved for the situation. If it works with a certain degree of efficiency cooling fins should not be needed, as the heat energy would be transferred into electrical energy and lead off to the load. I however, suspect that it would still be insufficient for the purpose, given constraints of weight and size.
I forget what exact metallic property causes the thermocouple effect, but there is an effect when ANY two dissimilar metals contact each other, in any temperature. This effect continues in a circuit if one is available. If not, it acts similar to a battery’s terminals, a nominal standing voltage builds up and stops according to a number of factors.
I like strawhistle’s thermocouple around the lamp’s chimney. The detractor of low electrical output for heat input is not a problem as crystal radios (as I understand it) are almost a non-issue to power, I seem to remember that they are even partially powered by the radio wave itself, please tell me if I’m wrong. And the advantage of a “no moving parts“, “solid state” setup means that there is no maintenance that would be required like that of a hand-crank generator.
atomicbeanie
Re: Thermopile?
I think you're on to something. Apparently several car manufacturers are interested in using standard engine exhaust to offload the alternator. I found this presentation with a bunch of nice details include equations and pictures of the BMW design (reported as generating 600W).
http://www.mae.ncsu.edu/academics/duke-energy-research/pdfs/misenheimer.pdf
I was thinking such a furnace, thermopile generator could be applied to a velomobile type vehicle with a plug in battery. The idea is even with a small amount of generated power, maybe the range could be extended burning any fuel (include carbon neutral sawdust or something):
Persona Non-Grata
Re: Thermopile?
When you initially described a burner box, I imagined that wood might be used. Where I live, that would mean a refuel (of already dead wood) is within arm’s reach of the roadside in most cases, where a roadside exists.
I am very surprised that a thermocouple arrangement worked so well as to produce 600 Watts. It appears that difference in temperature is much more important than total temperature, which would explain why heat dissipation is needed on one side, and its usefulness in space where the difference between outside and liveable environment is several hundred degrees. A car’s exhaust system does see much of the car’s waste heat, especially around the catalytic converter where partially burnt and unburnt fuel is fully burnt. A very hot spot as compared to atmospheric temperature. The other spot that would see a comparable amount of waste heat would be the radiator system.
The required parameters appear to be met for large vehicle, it even looks like it belongs there among the ducting. It should be feasible in some amount for smaller vehicles. The final factor unfortunately appears to be cost, the figure for their little racer was over $15,000, and it is probably a very expensive upgrade for BMW’s car. It however does appear to be a useful “do it yourself” upgrade for someone with lots of spare time and resources to play with.
Question, is that picture of the egg on wheels (velomobile) an actual picture or a concept drawing? It looks nifty and aerodynamic.
gasdive
Re: Thermopile?
It looks like a drawing to me, particularly the way the wheel spokes are blurred.
http://www.trisled.com.au/rotovelo.asp
This thing, the rotovelo, is real and reasonably cheap as it's rotomoulded.
Jason
atomicbeanie
Re: Thermopile?
That is a concept rendering (a cool one).
However there are lots of velomobiles in the world. I think they are a great starting point for lightweight vehicles. I think a thermopile will never get an award for efficiency, but as secondary power it could extend the range of these vehicles.
Ultra light cars are already on the way:
X-car
Aptera
And some of the first cars are great inspiration too:
Hollsman
Steam Car
Stanley Steamer
First Ford
