Vectrix cornering
4 posts / 0 new
kingcharles
kingcharles's picture
Vectrix cornering
I am a little held back to corner the Vectrix in left hand corners as I am afraid the hub motor will touch the ground and lift the rear wheel.
Right corners are no problem, I had the bodywork touch the ground often enough to feel comfortable.
Does anyone know which part of the left side of the Vectrix touches the ground first?
BurgerMario
Re: Vectrix cornering
Hi!
On the left side, the passengerfootrest touch the ground first :)
The previous owner of my vectrix have a little accident on the left side and the motor didnt have any scratches :)
Only the footrest have scratches..
I buy his vectrix and have painted new in VW Scirocco limesgreen :)
CU
MArio
-------- http://www.vectrix-forum.de --------
THE FIRST german VECTRIX Forum
kingcharles
Hi!
MArio
I doubt that this would happen in a corner because on the right side it is the bottom bit sticking out at the rear of the drivers footrest that touches the ground first. The passenger footrest is much higher.
Last seen: 7 months 2 weeks ago
On the bottom side of the vectrix there are a pair of platic protuberances that get the first scratches. I have "felt" the ground with them many times, but I've never get any scratch on the engine's cover.
