No responce from thumb throttle
2 posts / 0 new
bizybily
I get no responce from my thumb throttle. I'm getting a steady green light blink that means all connections are correct but no signal is being received from the throttle. I don't see any visable signs of problem. Anybody got any ideas?
robert93
robert93's picture
Re: No responce from thumb throttle
If you are properly set up with brake levers that stop the motor, that may be stuck, try disconnecting the brake lever wires. My currie does this.
