E&J 12V Lithium/LiFePO4 battery packs build in SLA cases to replace SLA batteries to use on UPS/electric scooters/golf trolley
E&J LiFePO4 battery packs,12V Lithium battery pack http://www.ejbattery.com/products_view.asp?id=439 ,the good choice to replace SLA batteries to applicat on power tools, e-boats, e-scooters, HEVs, BEVs, Uninterruptible Power Supply (UPS), electric medical devices, Portable PAPs, Solar energy, Wind power, military
Compared SLA batteries, LiFePO4 was much more expensive, but it had super advantages on the cycle life, lighter weight, eco-friendly. We are all in one world, we need to consider more for the environmental and use the eco-friendly power solutions for our electronics and battery operated products, such as power tools, e-boats, e-scooters, HEVs, BEVs, Uninterruptible Power Supply (UPS), electric medical devices, Portable PAPs, Solar energy, Wind power, military etc..
Although Lead-Acid batteries have been broadly accepted in various applications, and their cost is cheaper than Li-ion batteries, shouldn’t we be concerned about its efficiency, safety and pollution problems?
Now more and more customers considered the environmental problems, and began to choose LiFePO4 batteries to replace their
SLA batteries step by step. And this is the reason that E&J develop 12V LiFePO4 battery packs build in SLA cases to replace SLA/VRLA batteries which were widely used by customers from worldwide.
E&J LiFePO4 battery is high capacity, slim and compact, and it is also functional under various circumstances because of its high safety factor.E&J LiFePO4/Lithium iron phosphate battery pack is very good choice of storage system because of its outstanding advantages of long cycle life, safety, high c-rate charge/discharge and high energy density.
E&J LiFePO4 battery/battery packs 12V lithium battery 7Ah/10Ah/12Ah/15Ah/17Ah/18Ah/20Ah/21Ah/24Ah/25Ah/26Ah/30Ah/33Ah/35Ah/40Ah/50Ah/55Ah/60Ah/75Ah/80Ah/100Ah/150Ah/200Ah/300Ah are the good choice to replace the lead acid batteries to applicate on UPS, Solar energy, Wind power, electric trolley/buggies/scooters, medical devices, portable electronics, cordless power tools, emergency lighting/back up power, portable power stations,etc..
Anybody who want to learn more about E&J' LiFePO4 battery packs build in SLA cases, can link www.ejbattery.com
12V Lithium/LiFePO4 ATV/E-scooter/golf trolley/golfkart/golf car batteries
- ejbattery's blog
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
Comments
Re: E&J 12V Lithium/LiFePO4 battery packs build in SLA cases ...
thought this will interest you
there are two devices
one convert 12 volts to 36 volts and anther version that dose 12 volts to 48 volts
this means that it takes less battery's to do the same job with greater traveling distance
in my case for use with the E-bike I have
the device is called "deep sycle"
his web site is "www.deepsycle.com"
it's under $200 usd
the second device is called "Desulfator"
Sulfation, or lead acid crystal buildup on your battery plates
is by far the most common cause of battery failure, accounting for 84%
of batteries according to the Battery Council International.
We therefore junk our batteries long before the end of their designed lifespan.
The Infinitum Desulfator Battery Life Optimizer prevents sulfation
on your battery and reverses the existing lead sulfate crystals on the plates,
ensuring a battery with maximum lifespan and optimum performance.
This desulfation process can double or triple your battery life span
there are several listed on E-bay
http://www.ebay.com/sch/i.html?_nkw=Desulfator&_sacat=0&_odkw=Lead+Battery+Desulfator&_osacat=0&_trksid=p3286.c0.m270.l1313
the one I like is "Desulfator Battery Saver DEEP CYCLE/AGM/GEL/VRLA/SLA/MF"
http://www.ebay.com/itm/Desulfator-Battery-Saver-DEEP-CYCLE-AGM-GEL-VRLA-SLA-MF-/150514063352?pt=LH_DefaultDomain_0&hash=item230...
my only concern with the "deep sycle" is how much more of load the battery
has to deal with and if it will last the life of what it should posted for the battery
but with all that said and dun with the current 4 batterys that come with the bike
my travel distance go's from max 32 km to 64 km for 1 battery just buy it's self
so 4 gives me 256 km of distance on a single charge
or I could go with 4 heavy lead acid to get about the same distance at 70 amp hours
