Battery Testing for Dummies
3 posts / 0 new
kringle777
kringle777's picture
Okay,
I'll be the first to admit that I don't know much about electronics and batteries. I build and repair computers just fine, but the circuitry stuff is sort of a mystery. I know a bit about series and parallel circuits, transistors, capacitors, resistors, stuff like that. But measuring batteries and knowing what it means is something else--I've never had to do it before.
All this talk about a single bad battery in a series has got me wondering, how can I tell if I have a bad battery?
I don't ride my XM-2000 far enough to really tell if my range is being limited, and I imagine that even if things are fine right now, at some point in the future I'll have a bad battery (or two) and I'll need to do something about it.
So, what do I need to do to test my series of batteries? Measure each (in my case, 12V 38AH) battery with a multimeter? What would I be looking for? Order some PowerCheq's and attach them? Would that help anything? And finally, if I did happen to add a fresh new battery to a set of old ones, would anything be affected?
Any pointers would help. Thanks!
kringle777
Red XM-2000
Moss Green "Charger" ebike
Sacramento, CA
Gman
Gman's picture
Re: Battery Testing for Dummies
Sounds like a good mandatory class, it seems we only take it when there is a problem and the batteries are already starting to degrade.
I know basic electricity and Aircraft electrical stuff, that's about it.
I like the way usatracy did, he started off taking readings and recording them as soon as he received it. I'd say that's step #1.
Peace Out,
Gman
What is your vision for the future our growing community?
Gman
HCT
HCT's picture
Impedance ::: Battery Testing for Dummies
Been working with batteries for over 40 years , the first thing I do when trying to determine the condition of any rechargeable batteries regardless of chemistries is to measure its impedance , with lead acid pack , each cell is not accessiable and therefore one cell with high impedance will prevent any energy to be drawn out of the remaining cells.
When I encounter a high impedance cell or pack ,will tried to recharge at a slow rate C/20 to a low as C/100 .
Since any attemp to recharge a high impedance cell or batteries will most likely damage it by the heat created when forcing high current into high impedance .
Have been able to bring back cells of different chemistries that where as old as 30 years .
The process is slow , if the impedance lower after each charge discharge cycle , then the cell is recoverable to some extend .
Impedance measurement is the far most important parameter than voltage or even Amp/Hour , since having a 48 volt pack with 200 A/H capacity with a impedance of several hundred ohm will only allow you to take that 200 A/H over a 1,000 hours pretty useless for vehicul application .
It will do fine to power a transistor radio for quite a few months .
Heat is the surest batteries killer , heat generation is in direct proportion to impedance , both charge and discharge , so the lower the impedance , less heat, less damage to batteries , longer life
