Anyone had any experience with the X-Treme™ X-560
8 posts / 0 new
Gman
Gman's picture
Product Specifications:
Power: Electric
Watts: 500 (output capable to 600 watts)
Amps: 30
Volts: 36
Batteries: Three 12 volts Maintenance Free (heavy duty - lasts 3 years+
Tire Size: 13" with Chrome Mag Wheels (tire width coming soon)
Charger: Smart Charger Included
Tool Kit: Included
Speed: 17-21 mph*
Distance: Up to 22 miles per charge
Climbing ability : Climbs a 6% to 10% grade
Throttle Type: Variable speed control
Key Start: Yes
Seat Kit Included: Yes (seat is oversize for maximum comfort)
Braking System: Both front and rear drum brakes
Drive System: Chain
Deck: ABS Plastic with carpet kit included for foot area
Foldable: Yes
Head Light: Yes (full size - very bright)
Brake Light: Yes
Blinkers: Front & Rear
Suggested Max Weight: 300 lbs (tested to 400)
Carton Size (LxWxH): 46x14.5x26
Scooter Size (LxWxH): 49x29x39
Scooter In Box Weight: 79 lbs
Scooter Weight: 70 lbs
Electric Horn: Yes
Spring Loaded Seat: Yes (oversize)
Speedometer: Yes
Battery Indicator: Yes
Cargo Rack: Included along with optional trunk box
Since it's a chain drive, seems a very good candidate for mods if there is room for additional batteries somewhere.
amp_head
amp_head's picture
Re: Anyone had any experience with the X-Treme™ X-560
The 560 no experience but the 360 yes. Our family has 2 of them. All we have had to do in 3 years is charge them after every ride, lube/adjust the chain and fill tires with air. They are not very fast but they are fun.
Gman
Gman's picture
Thanks, I started off with something similar, but it was used. It was what they called a Dolphin knock off named E Scooter.
What size batteries are in the X-360? The X-560 probably has the same size since both are 30 AMP Circuits.
Peace Out,
Gman
What is your vision for the future our growing community?
Gman
Deafscooter
Deafscooter's picture
Deafscooter is Here...
}:) Craig have modded ths X-560 scooter before for my Customer who ordered it and She love it for use campus.. :)
The Virgin -> X-Treme™ X-560 came with 36volts at 30amps speed controller and thinning wire, soldered on connect
==> Here has three 12 volts at 12 ah batteries <== :( ==> The frame ( front neck ) can bend if you do jump <==
Deafscooter like this X-560 scooter great for country ride there has legal lighting system also horns , headlight, tail light, etc
if you want this x-560, You need do add to strong framework , better battery connect , install better amps speed controller
I report the X-560 is Rate 85% of 100% Great overall scooter if you do well care and smooth ride every day and keep crusin.
You are big Guy or fat Body ,You need add metalwork on frame & sturdy frame to heavy duty on scooter, better Vego wheels
heavy duty speed controller like 36 volts at 200 amps also custom made on gear ratio like 13T = 80T for your correct weight
Also the Brake system can convert to DISC Brake if you can do good welding and make bracket for calipter on place...
and better install LED light for sidelight, brakelight , also better 10 Watts HID lamp to bright light on headlight!! .. 8)
Craig Uyeda
Deafscooter
I still wanted one for my self to riding on bikelane & speed up 30-35 mph on 36 volts or 45 mph on 48 volts special batteries
Do you intertesting the order the nice X-560 scooter to modding by deafscooter then send email to deafscooter [at] yahoo.com
deafscooter
Gman
Gman's picture
Thanks for the information, I'll pass it along to the person that's interested in purchasing several of them for a project we're doing.
Peace Out,
Gman
Gman
Gman
Gman's picture
Deafscooter
Can you give me more details, or suggest a way to correct the problem?
Peace Out,
Gman
Gman
Deafscooter
Deafscooter added strong metal over the steering neck on Scooter
_____________________________________________________________
( The IMAGE( tag Not work for post the picutre this areas -<br />
(<br />
( Need Fix this Topic for IMG to post new picutre..<br />
(<br />
(<br />
(<br />
(<br />
(<br />
(<br />
(<br />
(<br />
______________________________________________________________</p>
<p>make strong sturdy stiff frame, dont get bended neck on steering</p>
<p>Craig Uyeda<br />
Deafscooter)
deafscooter
Gman
Gman's picture
`Deafscooter,
Thanks, were you trying to post a image of how it would look?
We need to come up with some cost estimates for several of them for a Environmental Education Grant ASAP.
Peace Out,
Gman
Gman
  • U156531
  • U156531
  • Shoney
  • Deadvx-1
  • OnTimeSport
  • ozzy40
