Solve high discharge problem for a lithium battery packs, high voltage and high discharge can be achieved.
2 posts / 0 new
high voltage an...
high voltage and high discharge BMS system's picture
Last seen: 13 years 3 hours ago
A excellent performance with high discharge BMS system, from 4cells to 32cells even used to a e-cars, most people dream to seek up to 150A continual discharged was realized now, please go to a professional company there www.szcoresun.com will find your real need.
Re: Solve high discharge problem for a lithium battery ...
confused?
You aren't trying to put 150A into power silicon as a giant switch are you?
Everyone else uses the motor controller and charger to terminate discharge (even if BMS controlled).
A contactor is used as a last resort....
150A continuous is easy (I've been doing it for years)....
