Need A Basic Electric Motorcycle Diagram
Gregski
I am looking for a basic yet detailed diagram of how to wire an electric motorcycle. What I have seen so far are diagrams of what I would call very advanced designs which leave me wondering if the person who is sharing the diagram with us is showing off or actually believes it can help others.
I like to take baby steps, so I am not interested in how to wire the entire bike with the regular components such as the headlight, horn, tailight, turn signals, etc you get the idea or with the latest in LiFePO4 battery configurations with a nuclear flux capacitor - jk
I am looking for how to wire a motorcycle conversion to make it go under the power of the electric motor with no extra bells and whistles. I know you will ask me for the details, but I believe a generic diagram will suffice for newbs like me regardless if we have and Alltrax or a Curtis controller, basically I am looking for a diagram that goes further than saying well hook up the batteries to the motor and the other end to the controller and off you go.
I know there are the "big" components (motor, batteries, controller), but where does the shunt go, where does the fuse go do I need a contactor, on/off switch, throttle, etc.
Here are more details as an example a 4 battery system of 12 volt deep cycle batteries, in series, hooked up to an Alltrax AXE 48 volt programmable controller, hooked up to the MARS ME709 motor, a fuse, a shunt (if needed), a contactor (what ever that is) what gauge wire to use between which components, etc
please help
fivari
fivari's picture
Re: Need A Basic Electric Motorcycle Diagram
I found somewhere, don't remember where of when, the following images of the Efun 1500W. Can be useful.
If the images are not large enough: I put the image of electric pieces and the diagram on line.
Two e-scooters 1500W 48V 30 Ah LiFePO4
tdnevmo
Nice fivari.
What is howo?
xm4000-li
What is howo?
The term appears to be tied to the hall sensors, as for the throttle the grey HOWO appears to be the sensor output back into the controller, and the motor hall sensors also sport that HOWO in their description, though all leads are properly marked there as +5V, GND and the outputs A, B and C. Maybe Amoyee Chen could enlighten us?
tdnevmo
Yeah i found out.
5V and GND and the signal back to the controller is the green one.
I have got this new kelly controller with regen and programmable things all over ;)
So i will rewire my eco switch, to be a reverse switch, and then i will buy a analog thumb throttle for regeneration :) Then all should be perfect.
xm4000-li
