Please help something bad is happening to my vectrix!
37 posts / 0 new
Vectrix99
Re: Please help something bad is happening to my vectrix!
Hi, was reading your post with great interest. I have much the same problem, but with Runke charger.
As far as I can understand the Runke will refuse to charge without temperatures. - Front sensors all show 60 degrees in Scooterdiag. (External=0)
I have not located the front sensor board yet. Just now I am wondering if it has to be the board, or if any other connectors i.e at charger might have the same effect(?) Or sensors? - I am not so fond of defective parts, since the service in Norway has broken down completely...
PS: Runke charger has had some odd behavior, since I got it like 18 months ago. It has refused charging from time to time. Have seen a message "No out", I think combined with yellow wrench. New attempt has been a reliable way to start charge.
lacitibi
I`ve got now everything (gridconnect pcan too)and some time but no luck.
I`m trying to use scooterdiag 2.1 to change the firmware to the adviced older ones but when I load any firmware to the right window the diag program shuts down with error.
Connection looks ok I have active can and the sw reads few things from the vectrix km,voltage etc.
I`ve seen that antiscab did firmware update on youtube and he is using diag sw v.101 what I cannot find anywhere.
How can I get it?
Or what can be the problem here that I cannot load firmware in diag prog?
Please someone help asap cos I`ve got only 2 days to fix it.
Thnx
lacitibi
Sorry is all ok now.
I can load firmwares now.
Sooterdiag folder must be in c drive root.:)
Vectrix99, Did you solve the "No out" error?
Vectrix99
Hello R. The "no out" message does still occurs from time to time, but it is stable, restart will always start charging.
I am waiting for a new mainboard for Runke, together with bms and other Lithium stuff. - Wonder if that will change that behavior.
Vectrix99
Hi R, just an update on the "no out".
Got a new main board for Runke, including firmware for Lithium 60Ah. Have not seen that error since, so I believe it has to do with old firmware, or 1. generation mainboard. (More testing in springtime..)
Together with new main board there were also instructions for a modification. A wire from mainboard had to be soldered to a circuit inside of charger.
  • allanbairstow
