Vectrix causes back pain
gln103
Guys,
I've ridden my Vectrix > 1,000 miles now. I have an issue that after I ride it (normal trip is ~20-25 miles/day), my middle back hurts pretty bad. I've been riding motorcycles all my life and never had this issue with other bikes.
Anyone else have a similar experience with the Vectrix? More importantly, anyone have a suggested cure (different seat, different ride position, etc.)?
Maybe I'm just getting old!
Gary
HubCap
Re: Vectrix causes back pain
Same here. I think its the feet forward position combined with high bars. Try riding with your feet in a position closer to a normal motorcycle so that you r feet are taking some of your weight not just your spine / ass.
Keep it shiny side up!
ofx210p
This is exactly what i found with many Harleys. As you tend to roll your spine in order to be feet-forward etc.
I guess this also depends on your height as i am only 5'7" or around 170 and i find that putting my feet as high as possible toward the front better than having them in a mid mount position on this bike but thats just a personal preference and i'd prefer to have even more length available. . Its not great and I imagine if you are any taller it could be really bad.
Just My 2c worth
oobflyer
oobflyer's picture
I think it's the suspension! I adjusted the rear shock to the softest setting possible, but the bike still takes each bump very abruptly - I have learned to very carefully avoid bumps and potholes ;-)
Last seen: 2 months 2 weeks ago
Yes, I had this same issue. The lower seat option helped a lot... just a personal opinion, you should test it before buying it.
pcarlson1979
pcarlson1979's picture
I don't have a Vectrix, instead I have an ERider scooter. I had the same middle back problem. But I've solved it by consciously relaxing my arms while riding. Keep elbows at 90 degrees and don't straighten arms like on a motorbike. Like in our motorcycle course, they say "loosey goosey". Since then I've been fine. I found myself with stiff elbows which puts all the bumps into my middle back. Whereas relaxing my elbows the bumps are now taken by my bum and soft seat.
72v 50AH CHL battery
350A Sevcon controller
8313km: Installed BMS -
