xb 600 15 mile range
Submitted by markxr7 on Mon, 04/16/2012 - 04:03
I have an xb 600 with 5 18Ah batts. (New) and only get 15 miles. What gives. Its supose to get 20- 25 stock wit 4 12v 12Ah batts. Any answers or options Mark
Topics:
- markxr7's blog
- sarim
- Edd
- OlaOst
- Iber
- AndresV10
Comments
Re: xb 600 15 mile range
My xb is 60v and only gets 15 miles. Stock 48v is 20-25 what gives any help
mark chojnowski
The 20 - 25 stock is with 20AH x 4 batts, not 12AH. If you've got a 60V setup, are you playing jackrabbit with all that voltage?
What do you mean by jackrabbit? I didnt think you could fit anything bigger than 14 AH. the 18AH's are too tall but I dont put the cover on. Maybe that also keeps the batts. from getting hot. and the fifth is under seat. Example: 5 x 18ah = 90ah AND 20ah x 4 = 80ah ?
mark chojnowski
Hee hee. "Jackrabbit" means full throttle off the line, using those extra volts to zoom away. The catch is that it uses far more current to enjoy the power than slowly rationing it out with gentle starts and moderate speeds.
The batteries in my XB600 were four 20 AH units:
They fit in like this (after I rewired the pack to 10GA/soldered terminals rather than the stock 14GA/ crimped terminals):
Battery overheating can be a REAL problem. If yours are getting above warm, you are either putting too much current in on charge or drawing too much out in discharge.
An example of what NOT to do:
A dried out battery in the pack never came up to full voltage, and the charger just kept running. The pack HAD lasted two years.
Mark
