Beginners Guide to Replacing Bad Cells
17 posts / 0 new
Caruso
Caruso's picture
With spare cells becoming more easily available 2ndhand, I thought I would buy some and attempt to find and replace any bad cells on my Vectrix. Although my Vectrix meets my everyday needs of a 24 mile round trip commute, it does suffer from the red light coming on when the battery level is indicating 1/3 full. This can easily happen towards the end of my journey if it has been a windy day or particularly cold. So to this end, I have purchased a module of 8 spare cells on Ebay and will document the end to end process for a beginner.
Caruso
Caruso's picture
Re: Beginners Guide to Replacing Bad Cells
Step 1 was to buy some spare cells on Ebay.
8 cell module
The cost was $150 for a module of 8. Upon visual inspection 1 cell is obviously bulged while another is slightly bulged. That leaves me with hopefully 6 good cells. From the stickers on the side the date of manufacture was 23 Apr 2007, and they were made in Hong Kong!
Caruso
Caruso's picture
Step 2 was to lookup how to remove the batteries in the Vectrix official workshop manual. From studying this it looks like the order of disassembly is:
Remove Front Seat
Remove Right & Left rear cheeks
Remove Step Through Panel
Remove Trunk Latch
Remove Air Plenum
Disconnect Battery
Remove Rear Battery
Remove Front Battery
Caruso
Caruso's picture
Step 3 will be to build an Inrush Current Limiter.
The Vectrix Collaborative Manual and this topic: http://visforvoltage.org/forum/7996-main-fuse-now-clarification-icl-inrush-current-limiter suggest an easy way to do this.
The parts I will need are:
4 x crocodile clips
1 x length of red wire
1 x length of black wire
2 x 240v 40W bulb
2 x 240v lamp holders to safely and easily connect the wires to the bulbs and hold all the stuff in place.
Caruso
Caruso's picture
I'm also going to use my spare module practise removing and replacing a cell in the module using the method in this topic: http://visforvoltage.org/book/ev-collaborative-hand-books/7089
And thoughts or advice on the whole battery check/replacement process would be appreciated.
HarryS
Caruso,
There is a lot of valuable information that Mik posted in the handbook. Pretty much all you need. Do you have a lot of time on your hands. If mot, leave this for the winter time. If you do it right, your bike will be out of commission for at least 2-3 months. I did a rebuild of a battery. You need to test each bank down to the cell level. That's 102 cells. You need to charge, discharge and measure, charge again... Lots of time involved. In my case, I found not one or two but 20 cells that needed replacement. You will get the hang of replacing individual cells eventually but it is not easy. Do you have a CB-2 battery tester? Do you have a smart charger that can safely charge each block back up? If not, there is the real potential of making matters worse. On the bright side, you learn a lot about this bike in the process.
Best of luck, if you have specific questions that are not answered by Mik's excellent posts I am sure there will be plenty of help coming.
Drew
Drew's picture
Dan, see my PM
Drew
Drew
CO2
Good is if you can post here video about Replacing Bad Cells!!!
Caruso
Caruso's picture
Caruso,
Harry, I plan on checking for bad cells just by looking for bulged ones. I plan to do it all in 1 weekend or 2...is this realistic?
Caruso
Caruso's picture
Dan, see my PM
Drew
No PM?
Caruso
Caruso's picture
Here's the start of my home brew twin globe ICL.
I plan to colour code the crocodile clips with tape, and mount the lamp holders to a block of something.
Drew
Drew's picture
Interestingly, I managed to use only one inrush current limit lamp (40w 240v) when re-initialising my bike. I left the positive terminal disconnected connected (supply to m/c) and then connected the Anderson (blue) connector. The lamp then went between battery +ve and the flying lead from the m/c. When it had gone out, it was just a case of keeping the lamp connected and fitting the M6 bolt though the m/c supply lead terminal and doing it up.
A point to note here that I know has been stressed before is that you can't take enough safety precautions with HVDC - I always work wearing arm length PVC gauntlets (gloves) and insulated tools where possible. Mik wrapped it up nicely with one of his post a while ago - if you're interested it was this post (#6) http://visforvoltage.org/forum/8918-new-battery-completely-discharged-vectrix-wont-give-any-sign-life
Further more, I now have a proper inrush current limiter, though it's wired really strangely and took a while to work out how to use it as it came with absolutely no instructions! Both methods work well and I'd suggest that the lamp method is considerably cheaper!
Drew
Drew
Caruso
Caruso's picture
I must admit I did think that only 1 resistance was necessary to complete the circuit safely, but I am naturally risk averse so if someone else has a working method with 2 then I'm happy to spend a little bit more and copy it.
I have enough knowledge to understand the risks. A 200amp DC supply as found in the Vectrix is far more deadly than a domestic 240v AC supply typically fused at 15 amps or less. So I too will be wearing rubber gauntlets and thinking carefully at each step what could go wrong and cause a short circuit either through me or some vital component. I don't want to kill myself or the Vectrix!
Caruso
Caruso's picture
Today I stripped down my Vectrix to get to the battery. The tools needed were a 10mm socket and a cross-head screwdriver.
But I chickened out when it came to disconnecting the battery. All the steps up to this point I knew what needed doing. But I couldn't see a way to make my ICL work when reconnecting the battery? I think maybe the crocodile clips are too big?
HarryS
Easiest is to use piercing alligator clips. They go on each side of the battery connector piercing through the insulation of the flat cable. Check for continuity first before reconnecting.
The Laird
Hi Caruso,
In the words of 'Hitchhikers guide to the Galaxy' DON'T PANIC.
Disconnecting the battery is simple. Just pull the Anderson connectors apart and you are there.
Re-connecting is also quite easy.
When you re-install the batteries, you will have the plastic cover off the rear battery. This is necessary in order to make the connections.
With the rear battery in place, first of all connect the negative lead (the one on the right side when looking forward) then connect the Anderson connector. You are now left with the positive lead to connect.
Connect one wire of your current limiter (the thing everyone seems to call the 'inrush current limiter') to one of the cell interconnecting straps about three or four cells back from the positive battery terminal.
Connect the other end of the current limiter to the positive lead (the one you want to connect to the battery). The bulb (lamp) will light up and then dim and go out (keep/maintain the connection for a further five seconds to ensure a full charge on the capacitors). You can then safely disconnect the current limiter from the positive lead and then connect the lead to the battery and tighten up on the bolts.
The current limiter is used for charging up the capacitors in the motor control module. The capacitors, once they are charged via the current limiter, will hold sufficient charge for up to twenty seconds after the current limiter is disconnected for a safe re-connection to be made.
The real danger to life is in the battery voltage. The danger to all else is in the available current (remember that, at the battery, there is no fuse and the available current is Voltage Divided by the cell internal resistance. By calculation the available current during a short circuit is approximately 1000 (one thousand) amperes) Don't short circuit anything, and Don't get you fingers across the battery terminals.
Despite all of this danger, I don't use insulated tools and I don't wear any gloves. I am well aware of the potential hazards and I take extreme care, every single move I make is thought through first and then carried out CAREFULLY.
I am not suggesting that anyone else does things my way, but I prefer to work with full knowledge of the danger of the situation at hand and the equally full knowledge that it is me that gets to be dead if anything goes wrong (I also find that handling tools whilst wearing gloves is a hazard in itself).
The alternative way is to try to make everything fool-proof in order to prevent accidents. It is my experience that, when everything is (theoretically) fool-proof, people get a false sense of security and THAT IS WHEN THINGS CAN GO WRONG.
I have re-connected batteries a dozen times using the above method.
I do not trust my luck, instead, I plan every move and take extreme care.
The Laird,
(Doing his own thing and telling it like it is, as usual).
Caruso
Caruso's picture
Thanks, that is the key point I hadn't considered.
