Vectrix Gearbox Clunking
7 posts / 0 new
jmap
jmap's picture
Hello everyone...
What's the probable cause of the Vectrix Gearbox Clunking? I've a situation like this one:
Thanks for any help...
turok
turok's picture
Re: Vectrix Gearbox Clunking
open it up and check the bolts that attach the gearbox to the motor
they've been known to snap :-)
no seriously, it's not a big deal to open it up, and at the same time you can change the oil.
that's what I should have done when I first heard something..
jmap
jmap's picture
Thanks for the recommendation. She's new so the oil should be ok. The Bolts you refer, to check them, the gearbox must be opened?
What's happened with you?
Hello everyone...
I'm hoping it's normal....Mine makes exactly the same noise.
kingcharles
kingcharles's picture
Mine too
This noise is normal.
It is called "Cogging Torque".
See this post (and preceding ones) http://visforvoltage.org/forum/4193-mik-question-about-gear-noise#comment-30415 for more details.
jmap
jmap's picture
Thanks Mik, I know what you refer, but it's not the case. This video is not mine and could be inducing in error, I'll record my situation soon as possible because I have 4 Vectrix in my garage right now and this one is the only with this specific sound that has being going worse as the time passes.
