Some work in progress on my Vectrix..
19 posts / 0 new
DoItYourself
http://www.youtube.com/user/EnergyFromAll
Any comment will be appreciated.. :)
ofx210p
Last seen: 9 years 1 week ago
Re: Some work in progress on my Vectrix..
Interesting changes to the firmware.
A few questions
Are the modifications to the motor controller firmware/dash or charger firmware
what original versions of firmware did you start with to make the modifications to.
what systems did you modify the firmware with ?
Is that a power cable or a canbus connector you are pulling out ? it isn't very clear in the video.
Sorry for all the questions its quite impressive mods
Cheers
Chris
Jonathanm
One comment - I have heard that this was developed in Vectrix before they went belly up - but I never knew that it was out in the open. How do you intend to share this information/software or modification?
I am for one interested in how you have acheived this.
Thanks for any info,
Jonathan
DoItYourself
All changes are mine .. I worked hard on the last version (1008) Control Module (ICM).
The firmware is currently in Beta (not working perfectly), but I am close to stability.
The first important thing I needed was the horn .. The original was ridiculous for an intense urban traffic ..
In the third video i've removed the gloves box and inserted in the front fairing an automatic retractable cable for powering the charger (4Wire 2.5mm^2).
Last seen: 4 months 2 weeks ago
really impressive. Is that firmware of the ICM compatible with MC1014b and BCthelairds? I'm really interested!
tt-tronix
tt-tronix's picture
The cruise-control feature seems to be really cool - especially for saving range. Well done!
I wonder what happens if you try to use regenerative braking while the cruise-control is on. Does it brake then too?
Tido
DoItYourself
At the moment i just freeze the Throttle data and restart reading after pressing any brake.
I'm already checking the regenerative flag sent from MC, but the regenerative brake is always a Throttle value so i must "decipher" it and if lower than a certain data.. send it to MC and disable the cruise.. (not more simple..)
In the same firmware i have removed the little beep for the horn and now it works like a normal horn.
CO2
Very good Job!!
DoItYourself
Thank you ;)
CO2
Any news?
DoItYourself
Yes..
cruise now can be disabled with brakes or regen
i've implemented a range for stabilizing neutral throttle position and over/under range defaults for maximum and minimum levels.
now the neutral position is fix and perfect. (the mileage range is improved)
when you are in "stop running" (switch run off) you can calibrate throttle as in original firmware.
ofx210p
I am sure you would have quite a few willing beta testers out there.
lol
So just to clarify a few things, simply because its a interesting subject and i'm really curious.
1. You said you were working on it before they went belly up, so you are an ex-vectrix employee ?
2. if that is the case do you have a software dev kit or are you simply reprogramming pic source code ?
3. is your source code assembler ?
4. and you are only reprogramming the ICM ? so essentially it is compatible with all motorcontroller versions and charger versions as i don't recall seeing any different ICM versions.
5. if this is the case will it work with the quite brilliant lairds charger code (my assumption is yes)
Obviously the last question on everyone's lips is if/when would you be likely to let this out into the open and would you be giving it to people or charging for it. (no pun intended)
I for one, am not opposed to paying someone for their hard work if its a reasonable figure.
Anyhow - thanks for reading. Hopefully you will not mind all the questions
Cheers
Chris
CO2
Very good!!!
DoItYourself
1. I'm not a Vectrix ex-employee .. I'm just a programmer and I work on microcontrollers since 1994 :)
2. I reprogrammed the source code
3. yes
4. yes, it is compatible with all Vx
5. I have the gold charger not silver , but I have seen the great work done by TheLaird and certainly works well with that.(and i have some ideas for improve the interaction with it)
I never shared my work because it was "beta" and still considered dangerous for sharing.. Now, after months of tests on the road and four new releases .. is fully functional. and still in progress with new features.
the latest version has:
- Removed the control of maximum lights current to install xenon kit without error on dashboard
- Cruise control activated from 20km/h
- Cruise control disabled with brakes and regen
- Fixed Neutral position (625) with range (610-640) only in "running mode" to allow calibration.
- Max and min levels fixed to avoid errors throttle while walking (within minimum calibration error)
- Selectable horn sound at start-up (normal or original)
ofx210p
Very impressive and thanks for taking the time to respond.
CO2
It's amazing what you can do... I'm "jaloux", like french said
Can I suggest 2 thinks in this new software?
1- select ah, when the bike is in charge
2- see voltage and ah when we ride
What do you think
DoItYourself
gasmatt
Really impressive stuff, DIY.
Knowing that you've tapped into the Vectrix code, & seeing your programming experience, & knowing you've got a gold Runke charger: Have you had a go at modifying the charger software (similar to theLaird's epic with the silver ESD charger) to stop it wrecking the battery? My Runke charger is happily trashing my pack & the only thing I can do is put a timer on the charger, which doesn't appear to help much- batthot & 53 degrees yesterday after 90mins charge from 3 bars starting point....
Not that I'm desperate or anything.
martinwinlow
Hi doityourself,
I would really like to try your firmware but more still I would like the charger (Runke) moved to allow a longer charge than the stock 30A. I have a comprehensive BMS working with my 40Ah LiFePO4 cells so even if the charger was unlimited the BMS would switch it off. I have a PEAK cable & scooterdiag software.
Regards, Martin.
Regards, Martin Winlow
Isle of Colonsay, Scotland
evalbum.com/2092
