I have a 2001 Ford Think Traveler folding ebike that is not working. I have replaced the batteries with new ones, the self-diagnostics all check out fine (throttle operation, brake interrupt operation, torque sensor operation, speed sensor operation). The problem is that when I turn the key on and then the handlebar mounted switch, the five LED's on the energy indicator panel just blink and the motor doesn't work when I start pedaling. Anyone out there have any experience with this??
Chuck
Ford Think Traveler
Sat, 09/26/2009 - 10:23
#1
Ford Think Traveler
- eric01
- Norberto
- sarim
- Edd
- OlaOst
We had the same problem with ours. We replaced the batteries and put a full charge and everything works great.
Daniel
770-315-5034
