Overcharged Lead-Acid battery - what to do?
16 posts / 0 new
I just found my 12V Lead-acid battery hot and bubbling from a charger malfunction.
It was connected to a 3-stage charger, which has been topping it up continuously since several months, while the 12V battery was supplying a bank of small battery chargers with "uninterruptable" power for testing and comparison of hundreds of NiMH batteries (a few at a time).
It has all been going very well until today....
For some reason the 12V charger decided to charge at 10A irrespective of battery voltage. This went on for probably about 9hrs, but certainly for a minimum of 4 hours.
When I found it, the 12V battery was making bubbling sounds and had an external temperature of 50degC (in 26degC ambient temp).
One drop of (presumably) acid had come out of a hole which looks like a vent.
I had "LogView" running, so I know that the 12Vbattery voltage suddenly jumped from the usual 13.5V to around 16V, with a maximum voltage of 16.67V reached at some time. For at least 4 hrs the voltage bounced around between 15.7V and 16.6V.
The battery is about 2 years old but has gone through very few charge/discharge cycles.
The battery label:
ACDelco
Marine/RV Maintenance free
Continuous use / Deep cycle battery
Model Number: HCM31LSMF
830CCA 200RC 110AH
Is there anything I can do to reduce the damage that might have been done?
Do you think this battery has been severely damaged, or can it take that kind of abuse for a few hours?
Thanks for any help with this, Mik
Re: Overcharged Lead-Acid battery - what to do?
Yes, damage has been done, especially to the electrolyte level and concentration. Such heavy overcharging tends to convert water in the electrolyte into Hydrogen and Oxygen gas, leaving the sulfuric acid behind. The result is a charged battery with excessively STRONG acid solution, that may be too low in quantity to fully cover and submerge all plates of all cells. Cells exposed to AIR do not last long! IF you can see the liquid levels of the cells, and figure a way to add DISTILLED water to each cell, so every cell is properly filled, (see an identical NEW battery) you may reduce the effects of this damage, otherwise, be prepared to REPLACE it soon! (Excessive quantities of plate material often break loose with heavy uvercharge, accumulating at the cell bottom, where this stuff eventually shorts out the cell.)
Jack_son
Mik,
As Maryland Bob stated [4 times] the battery is probably ruined.
If you can't restore it, I suggest you choose a REAL Deep Cycle Battery. A Marine battery means it is a poor deep cycle, and a poor starting battery, that pretends to be Both. It is fair for use as a marine battery, but poor for a RV use. There are better batteries for each service.
Once you repair or replace charger, buy a Deep Cycle battery. Check out specs on the Lifeline AGM batteries -- which require an AGM charger. They are sealed, and will last many years, with proper handling. They have a very wide range of discharge and charge amps, but should not be discharged lower than 50%. Look at their life span, with different discharge levels.
Do you actually have a UPS? Most have a built in charger.
What current do you require, and for how long?
Charge-discharge cycles are good for battery, if carefully monitored, for temperature, voltage, and current.
Jack_son
The battery label:
ACDelco
830CCA 200RC 110AH
EWheels EW475 eBike LiFePO4 36 V 10 AH Bat
Thank you, Robert and Jack_Son,
much appreciated.
It seems to (literally) boil down to this: "Maintenance free" really means "Maintenance impossible" for lead acid batteries.
I got a new charger, a CTEK 5A charger. I hope it is more reliable, but it gets very hot.
I guess I need to test the battery, but even that will not tell me if it is reliable.
The setup is designed to give me piece of mind during thunderstorms and power outages while I am running and logging tests on Prius NiMH battery modules.
The 12V battery is being continuously charged by the (now) CTEK charger (from the grid and through an isolating transformer).
The charger has more peak power than the loads are demanding (on average) and ends up in float charge mode sooner or later.
The loads are a SkyRC Quattro B6 charger (4 x B6 chargers in one housing) and one very similar RT808D charger.
I used to run CHG>DCG>CHG>DCG>CHG>DCG cycles at 0.6A and compare the capacity results and other parameters to determine how much exercise cycling is required before "final" power and capacity testing of the NiMH modules. Because this test takes almost 3 days and cannot be repeated (if interrupted and the data is lost), I rigged up the 12V battery as a UPS.
I also have an inverter connected, but usually turned off. This can be used to power the logging laptop once the laptop battery is empty, but requires manual plugging over.
However, by comparing the results found by the above method, I found that a single ((CHG 0.6A to 8.5Ah) > (DCG 0.6A to 5.8V)) then (CHG 0.6A to 7.5Ah) then (DCG at 30A/100A/30A) is sufficient to analyse the NiMH modules. This also means that data loss does not matter much, because if the grid power goes out, I can always just start again with the batteries that were being tested at the time. The results will still be reliable enough.
What it all means is that I don't really need this rigged-up UPS at the moment. But, I will sooner or later have another question that needs lengthy logging without data loss and I want to be ready for it.
I did not buy this 12V lead acid battery specifically for this UPS purpose, but rather as a general emergency standby power source that I can recharge from solar panels or generator or car if required. I thought it could be used for electric cattle fences, car starting, lighting, charging power tools or radios, computers, ADLS modem, etc etc. in an emergency situation. A jack of all trades, master of none.
Now I think it might be better to buy individual 2V lead acid cells, fully serviceable, for such a multi-purpose standby function. But they would be much harder to transport and use, particularly for people who don't know what they are doing.
Questions:
1) What would be the toughest, most durable and repairable battery for multi-purpose emergency standby? It should be able to be neglected for months or years, then work for years when needed. Clear battery walls would be nice so that the condition of the plates can be seen.
2) How can I test if the damaged 12V battery is worth keeping? It is black, there is no easy way to open it up anywhere to have a look at the insides. I could take it to the shop, or I could test it with a CBA3 (probably limited to about 7A DCG current) or my rigged-up halogen-lamp tester at probably around 170A. But none of this will tell me if the plates are in a state of accelerated decay due to the damage done.
Chris V
Chris V's picture
It looks like you have a good system working for you.
I've always thought that if no fluid can be added to a battery that is over sulphated from excessive charging, the cells are damaged and recovery is unlikely at best. As you know, the battery's condition can be determined one of two ways: with a carbon pile "load test" (that applies a calibrated load to the battery) or electronically with a special tester that measures the battery's internal resistance.
Equipment that uses a carbon pile for load testing requires the battery to be at least 75% charged. If the battery is less than 75% charged, a good battery may fail the test. So the state of charge must be checked first, and the battery recharged if it is low prior to testing. NOTE: The battery does NOT have to be fully charged prior to testing if an electronic tester that measures internal resistance is being used.
A good battery should be able to supply half its CCA rating for fifteen seconds without dropping below 9.5 volts. You had a rather ingenuous way of loading your battery by using "a CBA3 (probably limited to about 7A DCG current) or my rigged-up halogen-lamp tester at probably around 170A". That will tell you if its good, but there is no low tech way that I know of to get a measurement of how sulphated the plates are without an internal inspection.
Best of luck
Chris V
Chris V
bagpuss34
Last seen: 13 years 4 weeks ago
Hi, Not sure if this is related. But here goes. I have a sealed Lead Acid battery 17ah It was low on electrolyte so I topped it up with De-Ionised water. I haven't charged it yet but the battery has got very warm.
Any ideas? do I need to empty it? is it dangerous? should I move it out of the house?
How did you top it up if it is sealed?
When a lead-acid battery is severely overcharged, the electrolyte WATER starts being broken down into HYDROGEN and OXYGEN gas, which then leaves the battery, through its venting system. (YES, even the so-called "sealed" lead-acid batteries have vents, but these are one-way vents, which only open under abnormally high internal pressure, to safely expel the gases from overcharging, and reduce chances of the battery exploding!) As this overcharge proceeds, more water becomes converted to gases, thereby causing electrolyte level to DROP, and also increasing the concentration, or "strength" of the SULFURIC ACID left behind! This now "excessively strong and concentrated" sulphuric acid can damage the battery internally, as can any AIR that may reach exposed areas of the now uncovered plates. Length of TIME, and temperatures involved are factors in how MUCH damage is done, shorter time, and cooler temperatures are safer. If distilled water is added to a concentrated solution of sulfuric acid, YES, a considerable amount of HEAT it produced, sometimes enough to produce an EXPLOSION of steam and ACID! ( This is WHY, in chemistry lab, they tell us to add the ACID to the WATER slowly, rather than the other way around.) Normally, battery electrolyte is NOT so strongly concentrated as to create heat reaching the boiling point when water is added, but after SEVERE overcharge, concentration could get dangerously high, as seems to have been the case wherein our writer noted the very HOT battery after adding water, but hopefully, it stayed below the boiling point, thanks to the mass of the metal plates, which absorbed and spread the heat somewhat! After cooling, you can attempt a slow charge cycle, and then test the battery by slowly discharging and recharging it for around 3 cycles, to see what capacity and terminal voltage is available. IF this testing looks good, the next step would be to slowly charge the battery until it is again fully charged, and let it SIT, un-attended and disconnected from everything for about 2 weeks, after which a capacity test should be performed, to determine if it will HOLD the charge, and provide near rated capacity. (If capacity, terminal voltage, and charge retention are still OK, go ahead and continue using it! ( Expect the number of remaining cycles of use to be reduced, however.)
Re: Dead/Dying cells, BMS Problems
I have found that the BMS, or "Battery Management System" used to keep cells equalized and prevent over charge or discharge of the cells, can DEFINITELY be the culprit in many cases of premature cell death! If the dying cell(s) seem to always occupy the same physical location in your pack, it is very possible that your battery management system is constantly discharging that cell position, thereby taking the cell voltage too low, and destroying it! I find that many manufacturers of these systems FAIL to address the need to protect the circuits from the effects of voltage spikes, and/or RADIO FREQUENCY FIELDS, such as may be encountered by proximity to a nearby transmitting antenna, or generated in the vehicle, by switching transients from the motor, the charger, or other devices powered by the battery! This omission of R.F. Suppression filtering, bypassing and shielding of such an important part of the battery system may become a really BIG problem in the vehicle market, as it is all but IMPOSSIBLE to be certain a vehicle will never be operated in, or located nearby, a high level source of radio frequency energy, whether the radio frequency energy comes from a million watt TV or radio transmitter, a cell tower, a truckers "CB Radio and linear amplifier", a police/fire vehicle, a nearby HAM radio 1,500 watt transmitter, or your own cell phone/computer Wi-Fi system! Such radio waves are ALSO generated in NATURE, by nearby lightning strikes! ( for SAFTY and RELIABILITY, susceptibility to high levels of radio frequency energy and voltage spikes should be tested and guarded against, by adding needed ferrite radio frequency chokes, bypass capacitors, current limiting resistors, and feedthrough capacitors with proper shielding of critical circuit boards!) As HAM radio operator, with equipment capable of operation from 1.8 megahertz up to 10,372 megahertz, I have personally experienced some failures of these circuits, and lost a few cells as a result. Adding indicators to the BMS to show status of the discharge function, with an ALARM if discharge function remains active for an excessive time, may be of help!) --Perhaps EMI/RFI testing should be a REQUIREMENT of vehicles and battery systems, maybe some battery failures/fires and other malfunctions could be prevented! EMI=Electro Magnetic Interference, RFI=Radio Frequency Interference.
If you need a standby battery I would just use 4 x 40Ah LiFePO4 cells
you can leave them on the shelf for years (they have no self discharge)
float them at 3.4v when they're being used as a UPS (anymore than that and you overcharge them)
you could use a low voltage disconnect although you want one that draws nothing once the voltage drops low enough for it to disconnect the load.
you could also use some of the vectrix nimh batteries - only downside is if you put them in storage they won't hold their charge.
I came across this low volt disconnect:
http://www.evworks.com.au/index.php?product=BMS-LVC12
It draws nothing when tripped, so if you forget about the battery for a few years, nothing bad happens
Marvellous gizmos!
That should work nicely in the boot of a NHW10 Prius to stop the 12V battery from getting ruined. I might order one and try it out.
johnrajasundar
I think battery has been damaged due to overcharging. When we do overcharging at constant current, electrolyte temperature will increase, it is bad for battery.
1. We should maintain the electrolyte temperature of about 33 to 43 deg celcius.
If electrolyte temperature beyond this value, plates inside the battery will damage(plates shedding).
So capacity loss will happen.
2. Water loss is another problem for overcharging, if water loss is more, electrolyte will be highly concentrated, sulfation will happens.
John
MBT12222
I had "LogView" running, so I know that the 12Vbattery voltage suddenly jumped from the usual 13.5V to around 16V, with a maximum voltage of 16.67V reached at some time. For at least 4 hrs the voltage bounced around between 15.7V and 16.6V.Mik
What you describe is exactly a feature in most modern smart chargers to avoid Acid Stratification. Normally part of maintenance or equalizing step in charging. The duration of monthly equalization ranges from 2 to 16 hours. The goal is literally to BOIL the acid. Unless it boiled long enough to expose the plates there's no issue.
There seems to be false sense of serious damage that is unwarranted. It was necessary to post some actual information opposed to others impression's found above...
Charging a 12 volt battery 4hours at such voltages as 16 volts or higher, is TOO HIGH, for too Long if the battery was charging in a place at normal room temperatures of 70F or higher! Batteries such as many GEL CELL type may reach very high internal cell temperature, resulting in plate warping and damage, although SOME flooded cell batteries a MAY tolerate this for SHORTER time periods, it is not otherwise advised att normal, warm room temperatures, unless the battery is monitored to avoid excessive HEATING and depletion of water from the electrolyte! (COLD lead-acid batteries can generally tolerate higher charging voltages.)
DaneMarriott
As per my experiencethe battery's condition can be determined one of two ways: with a carbon pile "load test" or electronically with a special tester that measures the battery's internal resistance.
