Correct wire's color order in throttle's connector
7 posts / 0 new
Last seen: 10 months 23 hours ago
I have recently purchased a vectrix.
The throttle was dismantled by the previous owner, and I want to test it. I need to know the correct wire's color order in the throttle's connector (have a look at the pictures). I tried to found a description or a picture by googling, but I had no success. Anybody with a dismantled vectrix can take a picture of that connector?
Many thanks in advance.
robwhite
robwhite's picture
Re: Correct wire's color order in throttle's connector
image_2.jpgG/day R
Hope this is of some help otherwise I can take a picture of the connector.?
rob white
I already have the diagram. What I need is the correct color placement in the connector J19. Maybe numbers "1" "2" "3" refer to the correct order in the J19? In the kill switch diagram, numbers "4" and "5" appear also on the J19...
robwhite
robwhite's picture
I'll take a picture for you on the weekend if you like
rob white
robwhite
robwhite's picture
image_4.jpg hope this helps I think the two grey wires on the right go to the kill switch
rob white
Great shot! Thank you!
I've just discovered every wire has its diagram number code printed on it, 11, 12, 13. very useful!
