Re: Seeking ScooterDiag download/links/files + new firmware.
Hi Peter,
You will have to be a bit more specific as to which firmware files you want. There are lots out there including the original Vectrix ones for various configuration as well as The Laird's alternatives…
Regards, Martin Winlow
Isle of Colonsay, Scotland
evalbum.com/2092
If I recall, I was able to login to that site listed in the thread and find some of the software and documentation there (did not use it from there though, so I cant vouch for what's uploaded).
Better yet, there is also another thread here at visforvoltage.org that lists what I think is a more comprehensive site with all versions of the software available for download, with more descriptions for each of them. The direct link to the site is http://www.voltforum.cat and the thread here is this http://visforvoltage.org/forum/13793-installing-leds-vectrix-spotlight (go down to one of the posts by "R", search for "Catalan", the language of that site).
Registration to that site was also required and a bit of creativity was needed to read the "captcha" equivalent in that language :). But well worth it - all the software and docs seem to be available there. R, in the above-mentioned thread here kindly gave instructions to help with registering and where to locate the files once you register.
Hi Peter,
evalbum.com/2092
Peter,
Did you check our this thread here: http://visforvoltage.org/book/ev-collaborative-hand-books/10431#comment-59544
The direct link is this: http://websd-vectrixscenecom.webs.com/WEBPROTECT-filesmembersonly.htm (you need to register to see the content).
If you have not gotten it yet, email me.
