Vibrations
3 posts / 0 new
Ka252
Vibrations
Since this seems to be a common problem, I'll make a separate thread about the issue.
There seems to be a couple of possible sources of vibrations,
- Unbalanced front wheel
Easy to fix with normal balancing procedures.
- Unbalanced rear wheel
Harder to fix. Any ideas here?
Putting magnets on different positions and spinning the rear wheel with the motor on the center stand might work, but seems a bit arbitrary.
- Tyre is not symmetrical
Seems to be common with the standard Chinese tyre.
Throw away and buy a new one.
- Head bearing play
Tighten until no more play.
- Not enough or too thin oil in the shocks
How do I check this? Do I have to remove the shocks completely?
jateureka2
Re: Vibrations
Balancing the front wheel is covered in this YouTube video
The tyre may not be beaded on the rim correctly, could have picked up a nail/screw or other foreign object or could have worn patches if it has clocked up a few thousand k use.
Front forks may have uneven level of oil, or have stiction because of a missing axle spacer.
The rear shockies may have uneven air pressures and/or preload settings from one side to the other.
E-BIKES: [1]Ezee Sprint [2]Aprilia Enjoy Racing [3]eLation V2 e-bike kit on Trek 4100 [4]Bafang BBS01 kit on Fluid Momentum [5] FreeGo Hawk
E-SCOOTER: 2012 ZEV 7100 LR, 84V 60Ah nominal battery with 28 series GBS LFP cells
E-MOTORCYCLE: 2011 Zero S,
jateureka2
Re: Vibrations
Balancing the front wheel is covered in this YouTube video https://www.youtube.com/watch?v=Psyw5NwsZUo"
