VX-1 Li/Li+ Firmware Revision March 2015
VectrixLeaf
There is a new firmware in vectricparts web for litio version!!!! Has somebody install it? My vectrix is nimh with fantastic The Laird Software...so I can“t install it.
http://vectrixparts.com/service-materials
Heavendenied
Re: VX-1 Li/Li+ Firmware Revision March 2015
Yes, i've installed it on my Li+. Works very well but i'm not really sure what are the differences between this one and the R8010-42 because i used the 8010-42 for only a few days...
mpregal
mpregal's picture
I have found the "new" firmware some days ago.
I have used this combination for long time, with good results (too long eq time, but may be caused by some weak cells):
BC: R8010-42
MC: R2042-04
ICM: DIY-1708
BMS: BMS R54
Has anybody installed the new one from vectrixparts???
mpregal
mpregal's picture
Finally I have replaced the R8010-42 with the new LiFe40-3 firmware. I can't find new features, but the charger goes fine.
jasmim
I think that instead of accepting up to 42ah accepts up to 70 ah.
Vectrix Vx1 Li+ 60Ah
Vectrix99
Old post, but I just did.
Replaced NIMH with Leaf cells. Firmware as on website, except Runke charger. Had to replace main board in charger. SW is newer than the one on website. Do not remember number..
Also mounted BMS for 36 cells. Think it is somehow similar to Vectrix Lithium.
Everything works fine. There is a "menu" where you can see technical stuff while riding. Amps, Volts, Cell volts, temperatures and so on.
Charging is adapted for lithium. You can also adjust charge power up to 1500W, and Ah capacity up to 65 Ah.
Speed its 110 Km/h.
I like it :)
