Help repairing GIO hub motor freewheel sprocket
2 posts / 0 new
carlos1984
Hi guy unfortunately someone stole my last project which I mentioned in one of the threads. It was a Baja BE500 they came in my backyard while I was away and took it. I had the batteries out of it soI figured I would look for another bike and put the batteries into it.
I bought a GIO for 60 of a local site but my problem is that the freewheel on the hub motor is broken. The sprocket is there but the internal mechanism and bearings are gone. I am wondering where I can get a replacement. I20170814_170802.jpg looked online and found some freewheels but I don't know if it will fit. I took some pictures of the part. There is writing on it "Xiong ying Ning Bo"The internal diameter is 37mm while the ones I seen online are mostly 34mm. Any help or suggestions would be greatly appreciated. Thank you. Carlos
carlos1984
Re: Help repairing GIO hub motor freewheel sprocket
Here is the other picture with the writing on it.
