Has anyone having trouble getting trouble getting onto the visforvoltage without getting (( porn to pop up) .
BLUESTREAK
I have sent. A message to webmaster and asked for help but have not gotten an answer. So I cannot use google to connect to the the visforvoltage forum.l can only connect through AOL.
Webmaster
Webmaster's picture
Last seen: 8 months 6 days ago
Re: Has anyone having trouble getting trouble getting onto ...
I have received no such message from you or anyone. How did you send me the contact?
I have not put anything on the website which should cause Porn to pop up. I just checked and see nothing unexpected in what's presented. If you can be more specific I can take a look and address whatever's up.
BTW I moved it to General Community Discussion because it's off-topic for the Vectrix forum.
- David Herron, http://longtailpipe.com/
BLUESTREAK
Sorry about that MR> webmaster. I sent the first message from my old IPAD after 30 minuets of back and fourth try to signin on the I-PAD I don't usually use the I-PAD for this. I always use my computer and do not have trouble with using it (no porn pops up on the computer) myson brought me a new I-PAD apple PRO and we were setting it so after setting it up I was going to test it and I went to (VISFORVOLTAGE.ORG) and it would not let me sign-in then I tried the old I-PAD and it was their it did not let me sign in,it was in trying to find a way to sign-in that I went to the AOL (APP)that my son installed on the new I_PAD. and was able to sign-in and thats how I sent this message to you. I just tried my old I_PAD and only through it and my new I_PAD can I sign in to THE(V). I do not have trouble signing in on the computer. please excuse my typing I am not very good at it. thanks for any help you can do for this since it only pops up on the (I_PADS) when using GOOGLE).
Webmaster
Webmaster's picture
If I follow you right - the issue only shows up on the iPad's and not via your desktop computer. If that's the case, doesn't that indicate an issue with your iPad's?
I just tried with my iPad and see nothing unexpected.
I don't understand what you mean: "when using Google". Do you mean you go to google.com and enter visforvoltage as a search to find this website? If so, where along the process does this show up?
In my case I go directly to visforvoltage.org and see nothing unexpected.
BLUESTREAK
YES it does not happen on my computer I assumed it was block by my security. and I have all ways GOOGLE as my search eng. and just type in (VISFORVOLTAGE) AND THE (V) forum pops up and I go to the vectrix section comes up but when I use GOOGLE on the I-PADS I type in (VISFORVOLTAGE) and the forum pops up and the moment I touch the sign in as the sign in starts to come up you can see the sign in section but before can come up complete the (PORN) comes up.I did not know that I-PADS could get a virus or they could be hacked. thats why I have reached to you. I am not blaming you I am only trying to get this fixed. the (PORN) is disgusting to me and my wife. thanks for all your help. COOPER (AKA BLUESTREAK).
Webmaster
Webmaster's picture
The only thing I can think of is the advertising block that appeared at the left hand side of the window. That advertising block is controlled by Google Adsense, and I have no control over the content. Instead, Google does its best to determine what you might be interested in seeing as advertisements, and it does that by looking at past history of the usage of that device.
In any case I've removed that advertising block -- I'd intended to do so all along but had never gotten around to doing so.
If it is something else, let me know. I've gone through the login process on my iPad a couple times and nothing weird shows up.
