Motor Controller Replair
2 posts / 0 new
Jonathanm
Been a while since I was here...If anyone is still here do they know where you could get a motor controller repaired...Mine has been a bit dickey for a while - when I put the lamp on to reconnect the Andersons - the lamp would light up but never go out...for the last times I just connected the Anderson with a bit of a spark and it would still run ok...last time after changing out a couple of dud cells I did the same and the spark was a little more lively...
The bike will ride but will not charge...new board is €600 from Vectrix Parts - they are not interested in a repair anymore but if a repair will do the job I think its better. There was certainly no huge spark and smell...I think the component failure is fairly small...
Anyway looking for some suggestions?
Thanks and enjoy your day.
Jonathan
bkarlstrom
Re: Motor Controller Replair
You may want to contact
Sevcon USA Inc.
155 Northboro Road, Suite 1
Southborough
MA 01772
USA
T: +1 (0) 508 281 5500
F: +1 (0) 508 281 5341
E: us.info [at] sevcon.com
Vectrix43
