Check VX1 without main battery
3 posts / 0 new
k-Tracker
Hi, I have VX1 with dead battery. It currently has no title and I need to bring it to DMV CA for the inspection since I brought it out of state. That's fine if it's not running, as they will be doing VIN and emission checks. However, I was told they also need to check the actual odometer reading. Would you please suggest the way to turn on a bike without main battery by providing 12V power directly to an instrument cluster? I expect it's a motor controller drives 12V line, would you please suggest a pinout for this?
Thanks!!!
israndy
israndy's picture
Last seen: 2 years 4 days ago
Re: Check VX1 without main battery
You could just trickle charge the battery with a 150v charger. I have one you can borrow if you are in NorCal, come on by and I'll show you how to hook it to the battery to bring the batteries back online
______________________
k-Tracker
thanks! I found that I have DC-DC which is capable up to 120V. It actually works just fine for the purpose and can hold 105V @ 0.5A while the bike is turned on. Hopefully, DMV won't ask for a ride :)))
