Deafscooter Build off new "Limo Monster Scooter"
80 posts / 0 new
Buckeroo Bob
Buckeroo Bob's picture
Last seen: 13 years 5 days ago
Re: Deafscooter Build off new "Limo Monster Scooter"
You are going to be lopsided if you have to carry it many times. Ha! Too bad you can't design and install a side ramp up the stairs. Then you could walk it up with a little assist from the motor. Just thinking out loud!
amp_head
amp_head's picture
theleland,
You could ditch the lead weights and save a ton of weight. ;)
Deafscooter
Deafscooter's picture
Deafscooter is Here...
Deafscooter Got alum sheet and some vent screen for motor coolant panel
& put panel on belly skin on it and strong neck as steel like miltary tanker
Craig Uyeda
Deafscooter
Any Question --> Email=> Deafscooter [at] yahoo.com
deafscooter
Deafscooter
Submitted by Buckeroo Bob on Thu, 09/20/2007 - 08:24.=== Quote ======
here is install a side ramp up the stairs. make you bring your scooter to easy up
Buckeroo Bob
deafscooter
theleland
What do you guys think ... should the side aluminum be on the inside so you can see the frame or on the outside so the frame is covered? I don't know what would look better. Not sure if what I'm thinking about is even an option.
theleland
Matt - I think the batteries are made of glass, not lead =)
Buckeroo Bob
My vote is for expanded metal sheeting! Outside or inside, you could see the "guts" of the monster! My next would be "inside skin" to show off Craig's handy work. But, if you are worried about the prying eyes of others, then "outside skin" to keep 'em guessing. Styling suggestion: If skinned on the outside, put a slight "bulge" in the panels or cut a louver or place a tasteful air scoop somewhere to make it interesting. JMODO*
*Just My Own Damned Opinion!
theleland
What is expanded metal sheeting?
Thanks for the suggestions!
Buckeroo Bob
Well, here are some samples of generic expanded metal available in sheets, but if you scope out a fabrication shop you might find more interesting designs in the metal. A shop that does laser cutting of steel sheeting often has really cool scraps left over from cutting who knows what. Craig might know where some of these are or let your fingers do the walking.Expanded-Samples.gif
Buckeroo Bob
Here's a poor example of laser cutting left overs. This pattern wouldn't work, but you get the idea, I think.laser_sheet.jpg
Fechter
Fechter's picture
I'd vote for putting the sheet metal on the inside if you have enough room for the guts. That way, the frame tubes would protect the sheet metal from getting dented. I think it would look cooler that way too.
Deafscooter
Deafscooter Here ....
Here is Two Picture on Draft of Framework & alum sheet on belly (Peoples asked me)
==> Which your Favor Voted ==> Choice #1 or #2 on Belly of metalwork ??<==
Craig Uyeda
Deafscooter
Email ==> Deafscooter [at] yahoo.com
deafscooter
Deafscooter
Customer Requested, He want put heavy Duty (Thick Chain and Locker ) on side of belly.
Here is Picture what you think Chain & locker in storage by side of belly? it will get rattle!
it cause when ride scooter on road & it can make rattle noise on side of belly ( that i say..)
Up to Customer's Decide go ahead or change his mind... before i work on metalwork later
Craig Uyeda
Deafscooter
Any Question--> Email Deafscooter [at] yahoo.com
deafscooter
Buckeroo Bob
Can you line the "lock locker" with rubber sheeting (available at rubber supply stores)?p15.jpg
Deafscooter
Deafscooter Here...
=Submitted by Buckeroo Bob on Fri, 09/21/2007 - 13:44. Quote ======
The Rubber too thick for between space to space inside
The Belly's Space only 1" between inside alum to outside alum
The Thick & big Chain about 1.75 inches thick dia & High Secuity Pad lock is 1 inches
Customer, what you think & you want put use small chain, lock will fit in space storage
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Have either of you heard of the "boa lock" that Peugeot scooters has as a security option? It is a unique chain security system that stores in and retracts from the scooter. A little far fetched to try to duplicate, but something using a steel or aluminum length of tubing extending the length of the scooter might serve to store an equal length of security cable or chain. Admittedly, it would take a good amount of tinkering to get it just right, so maybe it's not worth thinking about. Ha, but I think about things like that! Good luck.
amp_head
amp_head's picture
How about putting the chain in the front.
Deafscooter
Submitted by amp_head on Fri, 09/21/2007 - 21:41.== Quote =====
==>> How about putting the chain in the front.
Customer wanted Built in charger station inside the neck of scooter ...
Customer wanted use Chain n Lock mount in side of Scooter's Belly..
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Tell Buckeroo Bob to mind his own business, but I had to make a drawing of my idea for the security chain. I know that whatever is decided on will turn out great. Good luck on a great project. I really appreciate seeing the details on how this scooter is evolving. Bravo to Craig and The Leland for sharing.Security_chain_tube_diagram.jpg
Deafscooter
Secured
deafscooter
theleland
That boa lock is a pretty great idea. I'm not sure though that craig can incorporate the design into the existing framework without increasing the overall dimension - which are already hitting the ceiling. If he can that'd be great.
Deafscooter
Submitted by theleland on Mon, 09/24/2007 - 10:29. --- Quote ------
it will about 2 inches dia tube and it would be add width about 2 inches on side of scooter
and it will about extra 2 inches on left side belly of scooter !!!! up to customer decide.....
here draw
Craig Uyeda
Deafscooter
Email--> Deafscooter [at] yahoo.com
deafscooter
Deafscooter
last question
Why Not, Put Chain / Lock IN Trunk Case on rear fender .. >>>> THIS IS SIMPLE <<<< like lunch too
Here is Deafscooter Recommeced for that design on Place Chain / Lock in Trunk.. also your Lunch box!
this is Final Question
Craig Uyeda
Deafscooter
Any question Email==> Deafscooter [at] yahoo.com
deafscooter
Deafscooter
DeafScooter-- Talkied with Customer Today & They happy with this final design....
This is Final Draw ( draft ) before i go work on Scooter & design on Limo Scooter
Craig Uyeda
Deafscooter
Any Question == Email=> Deafscooter [at] yahoo.com
deafscooter
Buckeroo Bob
I love it... Looks like the big brother to my little yellow "Electrical Banana" which Craig also helped with (controller and wiring tips)IMG_6225.jpg
Deafscooter
Thank for Buckeroo Bob posted little yellow "Electrical Banana" scooter
Here is See how alum skin inside the Frame ( many peoples vote #1 )
Now Deafscooter added the metal support on frameworks & look good truss Design.
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Deafscooter Gone to visit my other shop, do iron metal to make Motor case add on strong
front end for output shaft, We have filling 5LB Carbon steel ( iron ) to heat up and melting
Also Metal melting furnace from high Powered Arc & Argon filled in chambing then firing
then molten-metal pour into casting & make custom Monster DC Motors Housing Parts
!Warning! The Melt metal is very dangerous to handle the high temp yellow glow metal !
I use 15,000 amps to power ARC into Metal melting furnace for 15=30 minute to melt!!
Craig Uyeda
Deafscooter
deafscooter
DanCar
What do you guess the max speed is going to be? How much would a duplicate or something similar cost?
Daniel
theleland
Before hiring Craig to make my scooter I thought about ordering the batteries and electrical components, going to my local metal shop, and trying to build it on my own. Seeing now all the detail and hard-core metal work Craig puts in I realize there is no way! The scooter is coming together very nicely! I can't wait to post some usage reviews ...
Bob - I like your yellow banana! I actually saw it before we drafted the design for mine and the trunk idea I stole from you.
One design feature Craig didn't highlight is that the scooter is expandable ... if it turns out to be a lot of snow this winter I can order additional parts from Craig to transform it into a snow scooter.
All it needs now is some warp nacelles hanging off the sides!
Deafscooter
Submitted by DanCar on Tue, 09/25/2007 - 00:51. == Quote ====
Daniel
Hi Daniel,
There have choice 24v,36v,48v Fit the belly of framework
Between 40 mph on min to 80 mph on maxuim on battery
The Scratch to build custom made scooter and motor....
Minuim is $3250 to deposit to build the another one ...
I have another customer who want order this one & want biggest e-scooter
with EVT-168 HUB wheel with 48 Volts power make it go carry two persons
Craig Uyeda
Deafscooter
deafscooter
