Deafscooter Build off new "Limo Monster Scooter"
80 posts / 0 new
theleland
Re: Deafscooter Build off new "Limo Monster Scooter"
As for me ... I'm probably going to sacrifice speed for range ... I think 40 is probably about as fast as I could go without a helmet and still feel confident that if I wiped out I could safely duck and roll. Just about all my riding is in the city, and even on my old scooter going about 20 I was usually faster than traffic. Although I have a feeling that a month after getting the scooter I'll be thinking 40 is slow!
Deafscooter
Deafscooter's picture
Deafscooter is Here .........
Here is near Finished on Framework then i wait get plastic (lexan) for Rear fender protect from Speed Controller
and i wait for customer decide to Paint Color on Frame.. and later i add on Hinge door and locker on place, also
Customer want me do Drill Hole like through the hole for Jaw chain to secure the frame ( like Miltary Bullet hole )
Here is Picture the Finished metalwork...I put Tires , Speed Controller , Front Assembly , Stem w/ Folded , Alum.
Craig Uyeda
Deafscooter
Anu Question-> Email -> Deafscooter [at] yahoo.com
deafscooter
theleland
I think my ideal color would be a blue / silver ... or like a metalic blue ... I can't find a picture of blue silver, but in my mind it's like silver with a blue tint. (if that makes any sense)
It's looking real good! All it needs is a bumper sticker on the rear ... like "Eat my Voltage" or "Electrics do it better" or something ...
Up to 80mph? On those little wheels? With that steering geometry? Are you ~expletive deleted~ crazy!!! What RPM's is that motor putting out???
Are you sure that's the top end?
Also, 40mph on a stand up scooter sounds like I'd want a helmet. Duck and roll sounds cool until some idiot opens their car door right in front of you and the next think you know you're sailing through the air...
Best of luck - I just hope we don't end up scraping you off the pavement.
Deafscooter
Secured
deafscooter
Buckeroo Bob
Buckeroo Bob's picture
"Eat Sparks!"
theleland
That's funny ... actually, Craig has some other scooters listed on which he's gotten tickets going 70+ ... also, we talked about including 12" wheels, but that would have put me over the length restriction for the train.
My girlfriend is making me get a helmet after reading this site ... I already have a ribcap (http://www.ribcap.ch) for the winter ... it's made from the same nano polymer all the skiers used in this past winter olympics. It's soft normally, but is hard under stress. For the summer I need to find some cool bluetooth enabled headset. Anyone have any recommendations?
Deafscooter
Here is Deafscooter have lot busy time and doing little on alum deck with heavy duty hinge
then Tig welded on alum and Deafscooter sanded the welding to smooth on alumuium deck
also allow door access the battereries and charger also personal storage in neck of scooter
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
This is Craig Deafscooter Here...
I have lot Busy time and Wait for parts coming and build the motor
here is Custom Brush Plate , Air coolant end , Harden Cast housing
====> Note: Blur Picture to protect from image what i work on it.
deafscooter
Deafscooter
Deafscooter have doing lot work on busy machines shop & build off custom motor.
armature is work on polishing & balance in dyno then hi temp coating the armature
Warning Do not Try Flame to your own motor or you will go Hospital for serious burn
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Secured
deafscooter
NickF23
Very curious to know what those ribcaps are like. I remember seeing the technology on TV are they any good? wood they provide much protection? I currently dont ride with anything at the moment which isn't good.
Deafscooter
Deafscooter done on Motor Dyno tested ( bench test on monster ) today
Note:==> Secure ( no actual Picture what i doing on secure dyno shop )
Also Deafscooter wrote Tattoo on 3D Letter w/Mig Welded to Framework
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Can't wait to see what color has been chosen to paint that marvelous mass of metal. That's quite a test facility you have there, Craig. I would be very envious if only I knew how to do all that stuff. Ha!
Deafscooter
because Customer want Ferrari red color, Deafscooter Decide use OSHA Red Paint on Frame
Here is Ferrari's Color code is protected from copy matched color on painting (spray on thing)
Craig use OSHA Red Code (think safety to ride) color is red & Keep Ride Electric Scooter Safety
Here is Paint (already paint first coat is metallic primer on metal frame then paint OSHA RED)
Not Finish Paint Job it still more paint then dry and solid harden then repaint to two or three
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Deafscooter is here....
Deafscooter work on put toghter alum deck with key locker also motor mount in place
and speed controllere mounted then battery packs inside framework for wire dress up..
Craig Uyeda
Deafscooter
Any Question ==> email => Deafscooter [at] yahoo.com
deafscooter
Buckeroo Bob
Looks fantastic! Your best effort yet! This is the total package.
Deafscooter
Deafscooter Build-off the steering handle & stem also Folded mechinals
Note" Currietech has thinner tube wall compare Deafscooter's thickwall
Look the Between Factory Steering stem and Deafscooter custom stem
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Secured
deafscooter
  • tespila
  • CinemaCrazeX
  • dbayliss
  • Bikearenastore
  • dpw666
