XM4000LI acting wierd at startup!
2 posts / 0 new
tdnevmo
If i turn on the ignition, the motor has got heavy resistance, and if i roll the scooter backwards, or spin the wheel backwards when it's on the center stand, it begins reversing! With me on it. And it ignores the safety measure (brake and kick stand signals) It just keeps going 10 km/h with alot of stuttering? If i then turn it off and on, and push the scooter a bit forward, it will do the same, just in forward mode.
I just learned, that if i turn it on, and the wheel has got resistance, i can give the wheel a kick, and then the resistance goes away, and i can drive normally :O ?!
So my daily routine is to turn it on, feel the resistance of the wheel, and then give it a kick :o
Whaaat? Is it the hall sensors or the controller?
I have ridden it for 6000 kilometers now.
Please help.
I have disassembled the controller, but i can't see anything wrong with it, neither can an electrician i know. :/
tdnevmo
Re: XM4000LI acting wierd at startup!
And when it does this, it does not respond to throttle either.
xm4000-li
