Hi All
I have a vectrix that seems to eat motor controllers (internal IGBT failures)
It's back with me as it's not going again
encoder disc was damaged, so that has been replaced
however, I don't have an easy way to test the motor
The bike behaves as though it's down a phase (most likely a dead MC again, though I won't know for sure until I remove it)
this is the 3rd motor controller in around a year.
I'm wondering how I would test for shorted turns inside the motor, as being my only theory as to what could cause early IGBT failure
I haven't meggered the motor (I don't think I have access to that equipment anyway)
resistance between phases is lower than my DMM can measure accurately
I wish I had taken note which phase has failed on the last two motor controllers, to see if it's the same one each time
Hi Matt,
Could the encoder disc have been faulty when the last two controllers failed? If so, perhaps it could be the result of a timing issue with the firing of the Phase windings.
If the phase wire were being energised too soon (while approaching the magnets instead of already being adjacent to them) it could (I'm guessing) cause excessive load on the switching circuit within the IGBT.
I imagine it would be similar to the sudden shock load exerted on a piston and conrod etc. in a petrol (gasoline) engine recognisable by the pre-ignition knock (or detonation) which is often caused by over advanced ignition timing.
I once read an article on a R/C forum about over advanced BLDC motor running hotter, therefore it would be logical to assume that it must be drawing higher current to cause the extra heat, and switching higher current has got to involve additional load being placed on the switching circuit (i.e. MOSFETS or IGBT)
If the scooter in question has received a Leaf battery upgrade, which has a lot less voltage sag under load (and possibly running on a much higher initial voltage too) then this would also be placing additional current switching loads upon the IGBT.
Over the years, I have killed several eBike controllers after modifying them to produce more power, and I'm pretty sure that the Vectrix controller would also fail eventually if too much load was regularly placed upon it.
Well, that's my theory anyway.
Alan
the encoder wasn't damaged with the last two motor controllers, though i did require cleaning.
even with a damaged encoder, the current sensors on the MC are used for current limiting, so even if encoder feedback is wrong the hard upper current limit doesn't get exceeded
I cross posted here too: https://forums.aeva.asn.au/viewtopic.php?f=59&t=6417
after more testing, the issue with the MC is actually one of the 15v gate driver power supplies. the IGBT itself is fine
