Hey everyone, My name is Jason and I am new to all of this ev stuff. I have built an ev gokart with a Sevcon Millipak 4Q controller connected to a Etek-r motor. I have no wiring diagram so I am lost. I used one I found online, but the motor still does not turn....though the controller gets power. I have it wired according to this diagram - http://www.evparts.com/img/CT5115%20Millipak%20Wiring.PDF Any help you can give would be great! Thanks in advance....
- eric01
- Norberto
- sarim
- Edd
- OlaOst
I'm trying to figure this exact thing out myself (working on my schematic for this same setup).
From what I can make from the Millipak manual, I think the throttle input is on pin B10, not pin B11. B11 is the regen brake input, or so I think.
Does anyone have one of these working and how did you hook up the throttle? Inquiring minds want to know!
I found some better info. Looks like you can run the throttle on pin 11.
https://www.msu.edu/~tdc/play/electric/Millipak%204Q%20Accelerator%20Set%20Up.pdf
