Free wheel hub/sprocket that works with #25 Chain?
3 posts / 0 new
billremnant
billremnant's picture
*I have an e-scooter and I would normally post a question like this in the scooter section, but I thought there may be more people in this particular part of the forums who deal with sprockets and chains.*
I want to put a free wheel sprocket on my e-scooter so the resistance of the engine doesn't impact the scooter's ability to coast without power. Currently the engine puts a significant amount of resistance on the drive wheel and it slows you right down after cutting out the throttle.
So I have a 12 tooth sprocket off the engine and a 5.75" diameter sprocket off the drive wheel and a #25 pitch chain connecting the two.
I had hoped that I could find a free wheel sprocket to replace the tiny 12 tooth spocket (1 inch in diameter) but that would probably wear out too fast, so I guess I'm left to find a solution for the larger sprocket.
Anyone have a good source for custom free wheel hubs? I'm open to any and all types of solutions to make this work and I can post a 3d model of what the setup currently looks like to this topic if needed.
Thank you for your input :)
spinningmagnets
Re: Free wheel hub/sprocket that works with #25 Chain?
I was researching options for making a "Peltzer" E-bike. If someone started making a kit with a "left-side large diameter freewheel sprocket" that is easily attachable to a stock wheel there would be more innovation in this area.
If someone puts together a kit, make the freewheel part of a common interface "spider", so the outer edge (with the gear teeth) can be easily changed to get different ratios, like the front sprocket of an 18-speed bike.
I might even attach a TNC freewheel ($10) to the disc on a rear disc brake wheel which is used in a rear "V" brake frame.
Here's something I'm playing with:
I got the thick aluminum disc for $1 from the bottom of a skillet purchased at the thrift store. Attach the center first, then hold up a felt marker as you spin it to locate the outer edge mounting holes.
racermike39
racermike39's picture
Try www.tncscooters.com
once into the website, click on electric scooter parts. A free wheeling sprocket and mount and hubs are available for some pretty reasonable prices.
Spinningmagnets: That is very clever! nice work!
Racermike
