xm3k: moved the dc>dc converter, took off horn, replaced side plastic, other misc mods.
3 posts / 0 new
rydnseek
rydnseek's picture
I just got it all back together. I took all the plastic off.. trying to figure out how to get at the horn. Here's what it looks like naked:
When i finally got everything off, i tested the horn button. It was good. I took the horn off & put 12v to it. It squeaked a bit & got hot, but no noise. I fiddled with the screws on the back, but still nothing. I guess xtreme will send me a new one.
The wiring wasn't too bad.. it was tied down pretty well, & looked like it was sized right. The plastics are pretty simple, & i think it will be more streamlined with it on.. there isn't much weight to it.
I didn't care for where the dc>dc converter was, so i moved it next to the controller. It gets more air, & gives me the floorboard nook for smuggling or other storage.
Here's where it was.
new location.
The new plastic for the shipping damage came last week, along with a new charger. Both seem to work ok. I plan on using the factory charger when riding, for topping up the batts when i go to work. It draws very little power, & a thin extension cord might help for those more distant outlets.
Now i have to get my wife to get used to riding it.. she was the one who wanted a 'big' scooter. She will drive it to work when she's comfortable on it (middle of next century, sometime).
Re: xm3k: moved the dc>dc converter, took off horn, replaced sid
Hey rydnseek,
You beat me in the "skinniest" XM-3000 picture. I had all the front body work and floor pan off and the rear off - but not at the same time!
I'm thinking of replacing the seat with a bicycle seat on a pole and riding around with all the bodywork off like that. That should make it more obvious that it's electric! ;-)
rydnseek
rydnseek's picture
I thought briefly of leaving all the plastics off.. maybe making a shield for the batts.. but the combined weight of everything is just a few pounds. They probably give more back in aerodynamics.
But once we convert to li-on in a few years, maybe some further streamlining would be in order!
Of course, you guys with the 3500's will already have that, with a faster, more road worthy machine. This one is fine for a low speed electric, though. I tried mine out in high speed, but haven't run it any distance. Most of my riding will be 10mi or less.. mostly under 5. I probably should do some longer runs every so often so the batteries get a good workout!
scotty, Sedona, Az
