Can I use batteries with a higher AH rating?
lfoulkrod
lfoulkrod's picture
I just bought an eGo electric bike. I want to know if it is safe to use batteries with a higher AH rating. The bike came with 2 x 12v 34 AH batteries. Can I upgrade to two 12v 50 AH?
LinkOfHyrule
LinkOfHyrule's picture
Re: Can I use batteries with a higher AH rating?
Yup. Might have a time fitting them, though.
racermike39
racermike39's picture
Keep in mind that your charger(s) will have to work a little harder and longer to fully charge a larger AH battery. Still not a problem, if your charger is not fan cooled, you may want add a small computer fan and/or a heat sink.
Welcome to the EV experience!
Racermike
Ray_T
Ray_T's picture
Last seen: 17 years 1 week ago
While you certainly could use higher AH batteries, you'd be better off adding two more batteries to the existing set. put them on top of the deck. no cutting necessary and the stock charger will charge them. wire a plug onto the existing batteries and the new set, so you can easily remove them when unnecessary.
dogman
dogman's picture
Extra weight will make you slower, so you won't get as much more range as you may expect. The weight will make less difference if your ride is flat, on hills it may kill you enough to be the same as the smaller battery. Switching to Lifepo4 will cost big bucks, but the benifit is more dependable since that way you get a lot lighter with the same ah.
swbluto
So I take it you're running a 24V bike? What's wrong with 34AH? At the speeds you're probably cruising, it's likely it'll take at least 40 miles to drain them and at 15 mph, that's about 2 and 2/3 hours of continuous riding time. I probably couldn't handle riding that long.
But, yeah, it's possible. It comes at the expense of increased size and weight, though.
