XB-600 controller mosfets
4 posts / 0 new
hyperob
hyperob's picture
Anyone know the compatible mosfets for the xb-600 controller? I need to replace one and was wondering if anyone knew the correct specs.
JamesS
JamesS's picture
Re: XB-600 controller mosfets
Rob,
A IRFB4110 MosFet will work just fine and has a higher voltage/current rating then the stock part.
As for specs here is the link to the data sheet
http://datasheet.digchip.com/232/232-20788-IRFB4110PbF.pdf
Happy scooting,
JamesS
Happy scooting,
JamesS
hyperob
hyperob's picture
Awesome. Thanks James! :)
JamesS
JamesS's picture
Rob,
No problem, was doing some research on upgrading my controller and had the info handy.
If you would, when you have your controller opened up could you get the numbers of all the IC chips for me.
I should have done this when I had mine opened up and didn't.
Happy scooting.
JamesS
Happy scooting,
JamesS
