gear box oil
7 posts / 0 new
cdragut
cdragut's picture
Last seen: 17 years 1 week ago
gear box oil
what kind, and how much?
thanks, cd.
siai47
Re: gear box oil
I am not sure anybody knows exactly what it is. Mr. Mik had 80ml of oil in his gearbox, mine only had 60ml. For a refill, I would add even more. I have been running a very light weight oil (synthetic) at a 120 ml fill--no problems. It is just a spur gear system so no special EP additives need to be in it. I would think a 5-20 or 0-20 synthetic motor oil would work just fine. Factory oil fill was black after 500 miles. Just a note for everyone---I noticed some water in the oil. The source is the seal between the wheel and the motor. Water came from washing the bike. If you lay the bike on its side for any period of time, oil will seep out of the seal area. Next time I have this apart I will see what the heck is going on and if it is just my bike.
Re: gear box oil
It might be overflowing through the vent whilst lying down.
I was told 85ml are needed, that was third hand info though, I cannot vouch for it.
Even when I had filled the box with 85ml I could only remove about 60ml next time. A lot stays stuck on the surfaces.
Mr. Mik
siai47
Re: gear box oil
No, it is not coming out the vent, neither is the water coming in through the vent. When laying on it's side, some oil gets into the recess behind the wheel bearing and when you put the scooter back up on its stand, some oil has run out of the seal area. The top of the motor housing where the vent is, is dry. When I washed the scooter (and the rear wheel) I was careful not to get any water around the vent but the oil had water in it anyway. The seal is designed to keep the oil in the gearbox and not water out. Again, this might be a problem with my scooter or something I have caused. However a word to the wise would be to keep a hose away from the area between the motor and the wheel. I'll take a look at it again next week.
eyeinthesky
eyeinthesky's picture
Re: gear box oil
An email I got last year from Vectrix Poland regarding oil,... 88ml of Shell Hellix is in the planetary (I dont remember the number}
cdragut
cdragut's picture
Re: gear box oil
thank you guys... and now the stupid one: how do you change the oil? special tools needed?
thanks again...
CD
Re: gear box oil
thanks again...
Have a look at this thread:
http://visforvoltage.org/forum/3272-vectrix-real-world-testing-2-noise-levels#comment-19356
Click the image in the slide show to see the higher resolution picture.
Mr. Mik
