Need some pictures of a S-1000 Chain Drive rear end, Wheel size question
3 posts / 0 new
PDenbigh
Hi All,
I am working on converting a direct drive S-1000 to a chain drive S-1000 (http://visforvoltage.org/forum/4648-s1000-convert-direct-drive-chain-drive). I finally received the beaten up doner for the project.
I know you guys don't know me from the man in the moon, but I was hoping that someone would be nice enough to post some up close pictures of their chain-drive 1000 so I can compare mounts, locations, and design?
Second, can someone please clarify if the 12" wheel listed on the superkids (http://www.thesuperkids.com/12corewhca6s.html) is in fact a 12.5" wheel that will work on the S1000? The only 12.5" wheel they have listed has the older drum brake system and I'd prefer to keep the disc brake.
Thanks a ton to whomever can help!
Best,
Peter
PDenbigh
Re: ictures of a S-1000 Chain Drive rear end
Anyone?
Schwinn/Currie S350
PDenbigh
Re: Pictures of a S-1000 Chain Drive rear end
Schwinn/Currie S350
