3500li dc-dc converter failyer the cd didn't but I did
Well now i need a new 60V? cd-cd convertor found a short in the horn wire aginst frame butt not untill I blew the convertor and the flasher gizmo and one out therehave or know were I can get new ones ??? thanks Later
Comments
win32forth's picture
Isn't your 3500Li new enough that you can just order warranty replacement parts from Xtreme? If not, you can still order parts from them, and the converter shouldn't be too expensive, probably around $65.
Hope this helps,
Tom
thanks i didn't think of that !
