Needed new PCM for weird Polymer hub battery
flyfreebike
Hi. I have this battery that is out of a hub battery built by eneng in china, there are two packs, I measure the voltage on each at 22.2 volts. I do not understand. Each pack looks like it has 10 cells and they are paired together. There are 6 solder tabs on the top with like 5 small wires going to the pcm. The pack is connected to another pack, again 22 volts. The math does not add up.
Attached photo.\
I need a new pcm and fuel gauge, and charger.
But why do I read 44 volts. Maybe its a 48 volt pack? but by the cell count I would guess its a 37.
I dont know how to add photo, just email me and I'll send it.
P.S. I just getting into electric bikes and find this site very helpfull.
flyfreebike
Re: Needed new PCM for weird Polymer hub battery
P1010064_0.jpghere is the image.
LinkOfHyrule
LinkOfHyrule's picture
It's a 37V LiPo pack, but it'll come out higher (4.2V+ per cell) when fully charged.
What's wrong with it, exactly? Might not need all that stuff...
flyfreebike
I dont have a charger, and I would like to repack it in a case and use it as a second battery. there is a PCM. It has two heavery 18 gage wires and two small wires. I put my li-ion 36 volt on it for a second and the lights indicated charged. Do I need a higher voltage charger?
flyfreebike
OK I see now, I tested and indeed it spools it up. Now I just need to me sure of the 4 leads out of the PCM.
Regarding the case, non metalic for sure, would the packs be installed tighly as not to chaff, but I am concerned about too much padding and not enought air space.
  • XYZenergy
  • rlm1111
  • Eyama
  • shakscouriers
  • piotrsad
