XM-3100 Battery
boyelectric
XM-3100 Battery
First off, Does anyone have one of these, or have access to one?
It seems that the batteries are referred to as Lithium in some places, and SLA in others.
Thoughts?
Also, any other thoughts about these puppies?
tanks!
-a-
Mountain chen
Re: XM-3100 Battery
XM3100 equipped with greensaver battery.
By now 2nd generation greensaver battery in XM3000 & XM3100 already in USA for 1.5 years,any market feeback on its quality and life cycles ?
Mikie
Re: XM-3100 Battery
Mt Chen-- Hello and good to hear from you. If these are the silicone lead batteries you are referring to then yes I have 1.5 years of experience with them. I have them in my e moto 2000kw scooter and I have found them to be unsatisfactory. I have replaced them once, for $500 but they are heavy and they do not hold a charge after 1 years use. I do not recommend them at all.
mikie
Mountain chen
Re: XM-3100 Battery
What's the production date of your replacement batteries ? The date should be showed on battery.
jhg
Re: XM-3100 Battery
My XM-3000 batteries have about 1300 km on them (according to odometer), and I can barely do 10 miles after a full charge, without hitting the low-voltage cutoff. My XM-3000 arrived June 2008, so they're about a year old. Since my commute is 10 miles (or ~16 km), this represents about 80 commuting trips (and subsequent recharge cycles). I expected at least 300, so I would rate my battery experience at unsatisfactory.
Joe G. -- Commuting on XM-3000
