How do I test motor to see if it is ruined
8 posts / 0 new
electrogo
I recently had a flat on my back tire. I fixed it, but I guess I didn't get the nuts tight enough and the axle spun. I took the motor apart and all of the wires were still connected. So I put it back together and put it back on the bike. I did not connect the battery. I tried spinning it with my hand, but I could only turn it (not spin it) when I used considerable force. Does anyone know how I should proceed?
Thanks everyone,
Danga
Re: How do I test motor to see if it is ruined
If all the wires are good and reconnected properly then you should just have to connect the battery and turn the scooter on and the wheel will release and spin freely. The engine should be just fine from what I have heard so far.
electrogo
So what causes the wheel to lock like that?
clinton
captainslug
captainslug's picture
The motor will lock up if the power wires are shorted.
electrogo
Will it will lock up just because the power is not connected?
clinton
captainslug
No. You're only going to receive resistance to freespinning if the mechanical brake is applied, or the power wires are shorted.
electrogo
Ok. Without the battery or brake assembly connected I am still receiving resistance.
clinton
electrogo
Has anybody else experienced this?
clinton
