Vectrix mistery 4: The left brake random reset.
Last seen: 10 months 4 weeks ago
Today My Vectrix suffered a reset when I tried to read the temperature. The kill switch was turned off and I was pulling left brake lever.
I tried four more times and get another reset. This was relly scary, never happened before. I switrched off and turned on the bike, checked temperature and happened again!
I took the camera to record this issue and tried to read the temperature many times. The result is this video:
Every- 5-10 times I pull the lever I get a reset. Sometimes the lights of the displays turn off, but the bike is still on. Anybody experienced something like this? Is this another general SW bug or I should service the bike to the nearest dealer?
Thanx
undead
Re: Vectrix mistery 4: The left brake random reset.
Yep can confirm this happens to minne as well.
Is this issue permanent in your Vectrix? do you experience any other problems like the yellow wrench icon?
undead
The reset on left brake happens every now and then, i get the very rare CANBUS message here and there as well.
CANBUS has come up a couple of times during charging (that I have seen, normally it charges overnight.
Not sure if the two things are related but does not cause issue with day to day running of the bike.
Canbus come a couple of times while riding the bike. No other issue occurred while riding. Now its a week since I experienced the last reset. The bike behaves completely normal... SW bug?
