Deafscooter Build off the Red Schwinn s180 Frame to "Long Range Ride"
35 posts / 0 new
Deafscooter
Deafscooter's picture
Deafscooter is Here...
I took Red Frame to design the Framework for Long Range Ride on beachside biking path
Draw over the Frame to add on metal frame to strudy the frame and add on heavy battery
and add on motor mount and speed controlller aslo lower seat level and hand bar will be fit
Craig doing metal work chopping and wide frame for large battery then build off the battery tray
and add on metalwork to frame job to fit the battery and motor also speed control will on rear
of scooter frame and add on strong seat post support and chopped T-Steering bar to reduce
the wheel will be replacment with strong wheel with 12 mm dia axle and custom made sprocket
Craig Uyeda
Deafscooter
here is Picutre on before on Modified the frame work with four large battery packs
here is Pre Frame work ( overlaying the image with add on pipe work and metal on it
Deafscooter
Deafscooter Build off the Red Schwinn s180 Modding
Craig got the new Pipe from Steel Company, Deafscooter done Bending the new Pipe
Remove the Original Battery Tray from Frame , Chopped off the Front front support pipe bar
and Chopped the Original Seat Support bracket from Frame then wide fram for 40AH Battery
Please Dont Steal my Idea on Modding Schwinn Framework and i have lot work hard on modds
if I hear from you copy my ideas, i will not show you in future, because i have many done on it
Craig Uyeda
Deafscooter
Here is Release Picture on Framework "chopped to make wide frame for large battery to fitting"
deafscooter
Deafscooter
Re: Deafscooter Build off the Red Schwinn s180 Modding
Craig Done on Modding the Framework and doing Tube bended on Front to fitting Tube and Tig Welding job
The advanced Tig welding are Very difficulties to processes work
tungsten electrode got burned and too much foot Pedal controllers
and the filling rod to feeding to arc on metalwork ang got hole!!!
Craig dont want use Mig Welding cause Spray Spark into Fire Hazard !
Here is Picture Frame and not finished the add on metal support & seat post later.
Next work job => when i have time ( add new Pipe and seat post to framework )
deafscooter
Deafscooter
:jawdrop: Craig Using Tig Welding to glued the metal pipe on Framework & Beautiful Joints on frame.......:jawdrop:
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Buckeroo Bob's picture
Looking good. TIG welding is what my local friend used on my 2 project electric scooters. Once you get the technique down, the results are beautiful, eh?
Deafscooter
Craig Added some Metal to Framework get strong also Installed Seat Post & Batt-tray
Deafscooter got the strong Vego wheel and Tire will be install to Rear and Front axle
also add thick metal (see bracket) on custom made bracket to axle and Mount motor
Custom Front Fork to frame also add on strong metal & axle bracket for vego wheel
Here is Computer Graphic overlay before work on real metal and welding on frame..
Craig Uyeda
Deafscooter
deafscooter
This looks great!!! 8)
Good luck...
John H.
EV Wannabe
Ann Arbor, MI
Buckeroo Bob
Hope those little tires and bearings can take the weight. Coming along nicely!scooter.jpg
Deafscooter
Buckeroo Bob,
This very dangerous at high speed with small wheel and Jet Engine on Goped Scooter !
Craig did rode High Powered 0-70 mph in 3 seconds Monster Scooter w/ 9 In. wheel !
Check -->>> http://www.austinev.org/evalbum/395
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Ha! That wasn't me. I just "Googled" fatty on a scooter and got that picture. I thought this guys wheels were taking some high stress also. I'm sure you have thought out all the details. It's going to be a heavy weight, however! Hope you will "You Tube" it when it is finally ridden.
Deafscooter
Craig Build the new Rear Axle Mount for wheel on Frame,
Design the Front Fork turn Reverse & new axle Bracket
look the Picture ==>>Forward and Reverse front Fork => Compare to strong & heavy support the battery
Because when heavy battery pack get break forward fork, Deafscooter Turn Reverse Front Fork more stables
deafscooter
Deafscooter
Craig Done Modded the Sprocket & new Custom made Adapter hub installed to wheel Sprocket
also Welded glued the Axle Support on rear end on Framework and aligned perfect centered
& Chopped Steering stem to Reduce by 8 Inche down to sit down on seated postion e Scooter
Here is Picture of Pre-Finishing Frame work then later add on foot Peg and Kick Stand on frame
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Nice proportions for a scooter that must carry so much battery bulk. I guess I could wait and see, but I am curious where the foot rest(s) will be located. Once that is painted, it will look very professional...which Craig obviously is!
Deafscooter
Craig Finish the mod on Front Fork with reversed and new Bracket for Axle on front wheel
and Motor Mount on place then Craig will Secure the Motor Modified to 4,000 Watts Power
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Craig Finished Mod the MetalWork on Scooter frame & Protected the image by Deafscooter
Next Step is PAINT JOB is RED COLOR on Scooter Frame ..... And Craig Doing Modding the Motor. }:)
Craig Uyeda
Deafscooter
Next Step on Doing Modding the Motor & Craig will Secert the Armature, Brush Plate, Neodymium Magnets
deafscooter
Gman
Gman's picture
` :O
WOW
Peace Out,
Gman
Gman
Buckeroo Bob
Aw! Come on Craig, Just a little peek! Ha! Not a chance, I'm sure.
amp_head
amp_head's picture
Re: Deafscooter Build off the Red Schwinn s180 Frame to "Long Ra
NICE WORK CRAIG!!!!!!!!!!!!!!!!!!
Thanks for taking the time to share all those pictures.
It is fun to follow the progress of your project.
The motor almost looks like an EGO motor. :)
Gman
Gman's picture
` 8)
Buckeroo Bob, If he shows you any more, he'll probably have to kill you.
I will say one thing, Craig knows his s_it when it comes to E Scooters. Did he ever give you any clues what he was working on in China?
Peace Out,
Gman
Gman
Deafscooter
Craig Work on Rewinding Special Wire and Ceramics Coated on Armature
Allow Heat up to 750'F without Failed on wire and stay wire on armature
& stay special wire on armature at high speed spinning up to 25,000 RPM
8) No Picture will post on doing rewind wire , Special Ceramics on Armature 8)
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
TOP SECRET CRYPTO! I'm sworn to secrecy. Just kidding. Craig, hope you don't mind a little teasing. ;) You are a very talented businessman and I respect your desire to keep your skills and equipment proprietary. We're looking forward to the completed scooter. I'd love to meet your guard lady. She's a cutie!
Deafscooter
Craig Doing Custom modding the motor ( Secured Actual Real One )
But, Craig posted this Picture on Sample Hobby Motor for Your View
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Craig Finished wrote "DEAFSCOOTER" on welded to Framework,
the Paint on Scooter Frame with one dollar cheap Red Spray Can
then put wheel, brake cable, Modded Motor mount, Drive system
here is Picture with "Dummy Battery Pack" , Prevent the peep hole on Modding Motor vented
Later Deafscooter will get the new Specal "odd~even" Speed Controlller & Doped Battery packs
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Welding your name on the frame is a practical way to reduce the risk of theft. There would be no doubt who the rightful owner is. What is the final power rating of your modified motor...if I may ask? Is the odd-even controller how you will achieve 2 speeds?
Deafscooter
Buckeroo,
The odd~even is motor has neutral-advanced Brush timing system
like 0.0 and 0.5 when motor spining from speed controller's sensor
Craig Rode roadtest it very Fast Accerater and hill climbing _ Today
deafscooter
Buckeroo Bob
Craig, That is very ingenious. Did you come up with that or is it borrowed technology? Not that it matters, but it is just one more innovation you've added to your projects to make them that much quicker than the rest.
amp_head
amp_head's picture
So let me get this straight, the controller advances the timing of the motor based on the RPM of the motor?
Deafscooter
Matt, Bob
Adjusting the motor timing will have a significant impact on performance.
When speed controller sensor to allow to contol the brush timing plate Motor Spinning, the timing will self Adjustment
+ Even timing - Less rpms, more torque. ==>> For Power enough on dead start to acceration or Hill Climbing
= Odd timing - More rpms, less torque. ==>> For Speed Ride on Flat Ground or Coast Ride long range at low current
Craig Uyeda
Deafscooter
deafscooter
Buckeroo Bob
Are you saying rather than rotating the end of the motor where the brushes are mounted, you have a movable set of brushes inside that can be adjusted while riding? Or is this done electronically by the controller? Way too simple a question by me, but that's the extent of my understanding. :? I'd better stop and just admire what you have done.
Deafscooter
Craig Rode 3 Days road-test to Complete 172.8 Miles Logged on Modded s180 "Long Range ride"
Crusin speed between 18 ~ 25 mph as ride time and Top speed 53 MPH ( peak speed short time )
Craig not post Picture until August 11, 2007 at WRAD Deaf Bike Day
Until i will offical Release picture of my scooter after Deaf Bike ride...
8) 8) stay tuning on Visforvoltage topic .......... :D :) ;) :P :O }:)
Craig Uyeda
Deafscooter
deafscooter
newsletter editor
newsletter editor's picture
Craig
Sounds exciting, we'll be looking forward to hearing more about the event.
Arthea,
Newsletter Volunteer
